Old 06-11-2007, 05:08 PM   #1
klm325ix
BMW ROOKIE
Send a message via MSN to klm325ix
Fuel Injectors
Hey, does anyone know where I can get my fuel injectors cleaned and tested?
klm325ix is offline   Reply With Quote
Old 06-11-2007, 05:51 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
there's probably a thread here or on e30tech about cleaning injectors. they're easy to take out, just soak them in some injector cleaner, maybe?
if your gonna go that far, just buy a set of S50 injectors (19lb) already cleaned + flowtested. i did that with my car, and immediately noticed a difference. car pulls way harder, and seems to rev easier and idle smoother.
when i took out my old injectors, they had a lot of crud around the edge, but the port itself was super clean. so they werent clogged.
Old 06-11-2007, 06:24 PM   #3
klm325ix
BMW ROOKIE
ok Thanks.
Old 06-11-2007, 06:44 PM   #4
klm325ix
BMW ROOKIE
Would it be wise/feasible to get better injectors (Design type II as per the performance thread). Is it simply swapping the old ones or does the ecu need tinkering and do I need a fuel pressure regulator?
I ask this becuase I am in the process of rebuilding/getting a new head.
Also would I get better gas mileage with new injectors if I left everything as is(i.e. not tinkering with the ecu and getting a pressure regulator)?
Old 06-11-2007, 06:50 PM   #5
klm325ix
BMW ROOKIE
One more question. What about design type III?
Old 06-11-2007, 07:10 PM   #6
FuryriderX
cra.iX.y
FuryriderX's Avatar
what is design type III? the ones i put in (S50) are design II. no special hardware required. i just slapped them in, they connect up perfectly. its a 1 hour job, no joke.
havent gone through a full tank of fuel since the change, ill let you know when i do.
Old 06-11-2007, 08:20 PM   #7
klm325ix
BMW ROOKIE
Design Type III
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=190120305152
Old 06-12-2007, 07:00 AM   #8
Jamil
Jamil's Avatar
Check out http://www.fiveomotorsport.com/Injector_SetsBMW.asp
I had the same question about Design III. These guys sell OE Design III injectors. Don't know what it Design III is either.
Jamil is offline   Reply With Quote
Old 06-12-2007, 02:09 PM   #9
static
static's Avatar
don't forget to get a proper chip from MarkD for the s/m50 17.5# injectors if you don't want to run too rich
Old 06-14-2007, 08:49 PM   #10
FuryriderX
cra.iX.y
FuryriderX's Avatar
is this absolutely essential? i know its best, but i havent had any driveability/idle problems with no changed electronics
