Old 06-07-2007, 09:15 PM   #1
Trekz
Turning Signals Dont Work
While back one of my corners gor ripped out, so i bought some headlights with new corners, bought new socket, plug, wires, everything and wired it all up exactly the same way my other corner is wired up. But now when i turn on my lights on the dash the left signal is always lit (i changed left corner) but no turning signals work, both corners are just lit, but when only the the day time running lights are on, my turning signals work prefectly, i checked the wiring and it all seems to be wired up properly, what do you think guys might be causing this?
Trekz is offline   Reply With Quote
Old 06-07-2007, 10:12 PM   #2
vadim321go
vadim321go's Avatar
silly question but do you have the right bulb in there? like a bmw one not a CT one
Proud owner of a 95 325i
Old 06-11-2007, 12:12 AM   #3
Trekz
i got a part source bulb in there but hey i got the same bulb in my brake light and it works fine, and i asked the guy at bmw when i bought the sockets if the same bulb as my brake lights would work and he said yep. Il stop by bmw tomorow and pick up a bulb
Old 06-11-2007, 03:09 AM   #4
You have 1156 bulbs in there, you need 1157.
Old 06-12-2007, 05:42 PM   #5
Trekz
thankz, changed the bulb and it works now
Old 06-22-2007, 11:44 AM   #6
see how badass i am, i knock out bulb socket types without seeing the problem
