Old 06-04-2007, 01:49 PM   #1
wd948
wrong thermostat???
Since chritsmas, when i drive in traffic my car heats up, it goes almost to the 3/4 line, when driving on highway I am between the 1/4 line and the 1/2. If i stay too long in traffic, over 30minutes i also get my pressure light on. Could it be i have the wrong thermostat? it started when i changed it
Thanks,
Chris
wd948 is offline   Reply With Quote
Old 06-04-2007, 02:22 PM   #2
dgmorr
What pressure light? Oil?
Have you bled the system? Is your aux fan coming on?
Old 06-04-2007, 03:54 PM   #3
It could most likely be the thermo stat.
Different ones are made to open at different temperatures. (i think the dealer sells two temps, 80 and 75 degree ones)
In my experience i had the same prob until i went back and told them i wanted the lower temp of the two.
If you order from the states you can also get a 71 degree termostat.
Easiest way to check is to take the termostat out and check it, they are usually marked.
Old 06-04-2007, 04:12 PM   #4
magnus
magnus's Avatar
My guess is Fan Coupling needs replacing
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 06-05-2007, 11:19 AM   #5
wd948
i changed the fan clutch as well in november and the water pump, i bled the system for air too, ill check my thermostat
Chris
Old 06-05-2007, 04:17 PM   #6
Luke318is
BMW Fanatic
Luke318is's Avatar
I had the same problem with a new thermostat in my red car. we figured it may have been the temp sender that was actually wrong.
1982 528e -Sold.
1991 318is -Written off, parting out currently.
1984 318i -Beater while car shopping.
1990 ///325i -Imported Mtech2 model, purchased May 28
Luke318is is offline   Reply With Quote
Old 06-05-2007, 04:49 PM   #7
magnus
magnus's Avatar
It could also be your temp clock! It does fail some times and is not accurate!
Old 07-05-2007, 02:32 PM   #8
roaster
ill Finger
roaster's Avatar
Hi
My car is doing the same thing I'm being told that its the aux fan.
let me know when you find out what the problem is I will do the same.
roaster is offline   Reply With Quote
