Old 05-17-2007, 09:24 PM   #1
Alizay
Bad Man Wagon
Installing HID kit
I came across an issue when getting my HID put in. Low Beam Failure comes up all the time now. My friend who installed it for me said it was because the HID kit uses only one side for some reason, leaving the other side open, and therefor triggering the Low Beam Failure issue to come up on the console.
My question for you guys, what can I do, aside from disabling the console or anything like that, to prevent that warning from coming up? Is there a common fix that you guys know to get around that? I'm sure i'm not the only one who has had this issue before.
---My Ride---
2003 BMW 330i M-Package (E46)
LOOKING FOR:
Smoked Tail Lights, Corners and Side Markers for my 2003 BMW 330i
BMW = Bad Man Wagon!!!
Alizay is offline   Reply With Quote
Old 05-17-2007, 09:59 PM   #2
thinair
moderationistismingly
thinair's Avatar
Why would the HID kit only use one side? Mine have one bulb and ballast per side.
Old 05-17-2007, 10:07 PM   #3
carjoe
carjoe's Avatar
I read somewhere you need to throw in a resistor in line with the wiring. Something about the resistance being higher with halogens.
If i could find that thread, I'd post the link...
93 325is - sold!
2000 540ia- sold!
Old 05-17-2007, 11:48 PM   #4
Boots R
Boots, not boost
Boots R's Avatar
Tell your friend the real reason. Ballasts have a high start up power surge, but after initial powerup, they run on very low power, tricking the OBC into thinking the bulb has burnt out.
If you wire in a resistor to each side, you will eliminate the LBF.
Old 05-18-2007, 09:43 AM   #5
YAY!! everyone is right.
Sounds like your friend who installled the HID's used a relay. Relay's use battery power to start/run HID's, and only use stock wiring to trip a relay. (the stock wiring tells the HID's to turn on, but they actually turn on using battery power). The relay also only plugs into one side of your stock wiring.
HID kits, however, will still usually throw a LBF code, because as kevin said, they simply use too little power.
You can wire in a in-line resistor, i believe 6.8ohms, in line with both ballasts, and it will go away.
However, *cough* there SHOULD be a plug and play solution within the next few weeks.
Old 05-18-2007, 12:54 PM   #6
98Dinan3
98Dinan3's Avatar
^^^ shameless plug. hahahahahahahah. Oddly enough, I've never once had the LBF error on any of my HIDs. Maybe I'm just lucky, or I'm just THAT good.
Old 05-22-2007, 05:36 AM   #7
Alizay
Bad Man Wagon
hey Propr'one... when u have the plug and play solution, please let me know asap, i'll pick it up from you
---My Ride---
LOOKING FOR:
Old 06-22-2007, 10:53 PM   #8
Alizay
Bad Man Wagon
hey Question for u guys...
do you run your HID's in the daytime???...
If it blows out, what needs to be replaced?
---My Ride---
LOOKING FOR:
Old 06-23-2007, 02:06 PM   #9
Boots R
Boots, not boost
Boots R's Avatar
I run my HID's about 15% of the time during the day.
If the light blows out, you're most likely looking at a burst bulb, and you can pick up a replacement.
Old 06-23-2007, 02:45 PM   #10
^^or if you have warranty, like you do kevin, you can get a FREE replacement
Old 06-23-2007, 04:19 PM   #11
Ant118
BmwAviator
Ant118's Avatar
I run my almost all the time since only one of my AE's work lol . so what ever the price for new bulbs isnt bad.
1997 Estoril Blue ///M3 - Track Car
2011 Alpine/Black 335is
Ant118 is offline   Reply With Quote
