Old 05-07-2007, 04:51 PM   #1
Bainze
Dogleg
Bainze's Avatar
ecu question
can anyone repair a motronics ecu off a 325i?? how can I check if the ECU is actually bad?
If not... whos selling?
Bainze is offline   Reply With Quote
Old 05-07-2007, 05:43 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
well what are the symptoms? i dont think it would be very easy to repair the ecu itself. are you _sure_ its bad?
Old 05-07-2007, 08:29 PM   #3
Bainze
Dogleg
Bainze's Avatar
the ecu seems not to be responding at all the car dosent even crank
Old 05-07-2007, 09:40 PM   #4
The Sly
The Sly's Avatar
If it does not crank then i would check battery or starter but not the ecu.
The Sly is offline   Reply With Quote
Old 05-07-2007, 10:00 PM   #5
hernando
Probably won't stay running with a bad ECU but I'm guessing it should crank too.
hernando is offline   Reply With Quote
Old 05-07-2007, 10:04 PM   #6
FuryriderX
cra.iX.y
FuryriderX's Avatar
or even the ignition switch. do any lights come on on the dash? anything that would indicate that some power is getting somewhere? do the dome lights come on when you open the doors? is the battery even charged?
Old 05-07-2007, 11:53 PM   #7
Bainze
Dogleg
Bainze's Avatar
the cluster lights turn on... The battery is fully charged... thats why my mind went directly to the ecu.... my o2 sensor is toast, does that affect it?
Old 05-07-2007, 11:57 PM   #8
Eurostyle
Eurostyle's Avatar
No, the car will run without the o2. From what i remember, the car should crank even without the ECU, and in general i would look at other things then the comp.
Eurostyle is online now   Reply With Quote
