Old 07-05-2007, 06:28 PM   #16
paul christians
87325is///MR.EVIL
Originally Posted by 90E30i
Thanks Paul
BTW...I'm thinking of of putting these stickers on the back window...should make it easy to get some races..
cool man,but it does not take much to say that.....when the car is you should hook up and go to the track.....
87is325///2.7L..EVIL.....
Old 07-13-2007, 04:39 PM   #17
SweetnessGT
Looking like a gorgeous rebuild - I love it when people take the time to make the parts look as good as they work, internals included.
What size turbo is that? Did you fabricate the turbo header? Looks good...
Yeah those are just IM runners not ITB's... how are you going to setup the plenum, I see you have the stacks in there or at least that's how it looks...
The IC looks a little, beat, one or two bent fins. How is the inlet/outlet config setup I can see it's probably facing the engine - you gonna run the pipes under the rad support?
I love seeing the progress of a car - any car - being assembled and created. Good work.
-Chris-
Sweetness
Turbocharged
SweetnessGT is offline   Reply With Quote
Old 07-17-2007, 12:09 AM   #18
tarek hazime
BMW4Life
great work keep it up...by the way thnx 4 the advice....
oh what engine management u usin 4 ur set up....
tarek hazime is offline   Reply With Quote
Old 07-25-2007, 02:24 AM   #19
90E30i
90E30i's Avatar
Its slowly coming togather. Motor is togather and rebuilt with ETA bottom end.
Old 07-26-2007, 02:57 PM   #20
90E30i
90E30i's Avatar
-Chris-
Turbo is a WH1C with an 18cm2 housing from an HX35. Manifold was made by buddy.
The plenum is gonna be a round 4 inch tube, I'm keeping the design simple for the first mani.
I'll post some pics of the IC when its done...and for 120 bucks I can't complaint about a few bent fins.
I'm gonna be using MSII with extra code for EMS.
Old 07-27-2007, 12:12 AM   #21
SamE30e
SamE30e's Avatar
Is the engine stock internally?
Did you swap the IS head on the ETA bottom end?
85 325 - Turbo M52B28.
Old 07-27-2007, 02:57 PM   #22
90E30i
90E30i's Avatar
I swapped the ETA bottom end, other wise stock.
Old 07-27-2007, 04:22 PM   #23
SamE30e
SamE30e's Avatar
Oh ya, because you have the 2 door, crap I couldn't count the doors, you don't need to do what I need to, its the opposite lol.
Old 07-27-2007, 10:08 PM   #24
tarek hazime
BMW4Life
nice so bone stock block/pistons/rods--i guess they would take the boost? no..
BMW4LIFE
Old 07-28-2007, 10:26 PM   #25
SamE30e
SamE30e's Avatar
They will take boost. With the ETA bottom end, it lowers the compression. Low compression + Turbo = happy engine.
Old 07-29-2007, 03:36 PM   #26
90E30i
90E30i's Avatar
The reliability and durability of the setup will depend on proper tunning. As long as the motor is tunned right this setup should be very reliable for about 15-18 psi. That much boost with proper setup will give you about 350-400 wheel horse power, which is really good considering that its only a single cam 12 valve motor and all the parts are OEM.
Old 07-30-2007, 09:17 AM   #27
SamE30e
SamE30e's Avatar
The only downside to that is, it is more likely to suffer from engine failure in a mishap.
Old 07-30-2007, 05:41 PM   #28
tarek hazime
BMW4Life
true a good tune is 60% of engines preformance & longitivity...
as i read the e30 stock rods of M20b25 r forged...also the pistons r pretty
tough made... by next month i wont to rebuild my motor(stock rebuild,MLS hg, and head bolts...mainly)...
so anxiuosly waiting to see how ur setup goes....
what clutch ur using?
BMW4LIFE
Old 07-31-2007, 02:18 PM   #29
90E30i
90E30i's Avatar
I'm gonna be using a stock "I" pressure plate with Clutchnet's 6 puck sprung disc.
Old 07-31-2007, 10:47 PM   #30
tarek hazime
BMW4Life
kool...that'll do great...
hey -90E30i-would u refer me to some one around TO area for Msquirt installation.i live in windsor but its worth the drive ...sorry if iam out of the main topic here...and where did u buy all engine internals from for the rebuild...
thnks
BMW4LIFE
