Old 05-01-2007, 08:28 PM   #1
bvw
white smoke
white smoke on start up and when i get off the gas. valve guides ? 90k on motor 18 pounds boost how hard is it to replace valve guides m10 motor
bvw is offline   Reply With Quote
Old 05-02-2007, 01:58 AM   #2
White smoke is coolant! If its a boosed motor I whould say you need a headgasket...
Old 05-02-2007, 07:29 AM   #3
Boots R
Boots, not boost
Boots R's Avatar
^^ +1
Old 05-02-2007, 07:10 PM   #4
bvw
big job to do head gasket how much is gasket some times it smokes some times theres no smoke and if i put my finger on the breather hole on the valve cover lots of white smoke.
Old 05-02-2007, 10:05 PM   #5
///tyron
///tyron's Avatar
u shoulda stayed under 10psi with the stock head gasket. imo sounds like a head gasket to me aswell. switch to a thicker head gasket and that should lower your compression ratio aswell.
///tyron is offline   Reply With Quote
Old 05-02-2007, 10:50 PM   #6
bvw
where can i get a thicker head gasket. and when i plug the hole on the valve cover smoke instantly comes out i guess do to blown head gasket
Old 05-02-2007, 11:26 PM   #7
paul christians
87325is///MR.EVIL
XXX2....you need a new head gasket and maybe check the head too now....
87is325///2.7L..EVIL.....
Old 05-03-2007, 11:05 PM   #8
jm1602
jm1602's Avatar
Smoke!
White = coolant - blown head gasket
Grey = oil - valve guides, rings blow by etc.
Black = rich!
Leak down test is your answer dude.
Prolly valve guides. My advise is to do it right, once. Marcus Glarner Motors.
Old 05-03-2007, 11:17 PM   #9
Boots R
Boots, not boost
Boots R's Avatar
Black = rich!
Green flame = fast and the furious!
