The anticipation is over..my car is now ready thanks to Bimmersport Automotive. I had the guys do a long list of changes to my car over the winter. I dropped it off middle of January and just picked it up today. To introduce my car, it is a 2002 330ci Steel grey coupe. I have an extensive amount of work done, heres the list:
ASA S/C w/ upgraded TM-15 blower @ 10.5psi/intercooled
Technik Supercharger cams
Custom tuned software for cams and 40lbs injectors
Technik/Spearco Oil cooler set up
Technik Headers
Random Technology High-Flow cats
Supersprint exhaust system (full length)
KW Variant 2 Coil-over system
E46 M3 6 Speed tranny
E46 M3 3.62LSD
UUC 8.5lb flywheel/M5 clutch set up
UUC Evo 3 SSK w/DSSR
UUC Red TME w/enforcers
Autometer Phantom guages (oil temp/pressure, fuel pressure, AFR, boost)
UUC Sway Barbarian kit
AA front and rear shock tower braces
Full Hamman kit
19x8.5F 19x10R Hamman HM2
Umnitza Predator Chromium
Brembo rotors and PBR pads
UUC stainless steel brake and clutch line
So thats the total set of mods that was installed over the past 2 years by Bimmersport. I walked away happy after this install just as much as I did the first time I met charlie, when he was working out of his house. I can't forget about Jonny_blaze, funny guy by the end of it he knew more about my car then i did. Props to him and the crew there.
All in all a big thanks to them for a good job
I hope to see you guys on the cruise on May 5th, ill be there with the Bimmersport Crew if you wanna come say whats up.
Also thanks to Greekthang for the referal
Jonny get those pics up!
