Old 04-29-2007, 11:54 PM   #16
I was going to try mine this weekend, but I worked on my and wife's bikes instead. I'll take pics and give general impressions after I'm done.. However, on mine, I have a lot of play caused by something worn / broke, so it may be different. If yours is tight, I think you can just unhook the shifter linkage, pop out the old shifter, pop in the new one.. I heard about 30 mins to do.
Old 04-30-2007, 05:10 AM   #17
Willy
Willy's Avatar
hey everlast,
pls do post some info on your project, thanks. i've looked up the parts to the upgrade and the site i read up on lists the shift lever as-well as the nylon ball joint, washers clip and bushings etc. etc. are you going this far into detail or are you just swapping the arm?
oh yah my shifter now isn't tight. it's got a fair bit of give when it's in gear.
Willy is offline   Reply With Quote
Old 04-30-2007, 09:48 AM   #18
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
yea i need help with mine. i dont want to put one and screw somthing up
i think im gunna make one. since all you have to do is make the bottom after the pivot a bit longer to get the mechanical advantage the other ones get you
86coupe30 is offline   Reply With Quote
Old 04-30-2007, 10:02 AM   #19
I have all the washers, clip, the nylon cup, etc, and a z3 1.9 arm. My shifter hits the console to go into reverse which is pretty common.
Old 04-30-2007, 10:07 AM   #20
86coupe30
1990 325is
86coupe30's Avatar
oh yea, mines soo sloppy when its in gear, its kinda weird, and mine hits the console to get it in reverse too.. i just want my shifter to feel alright i dont care so much about how notchy it is, i just want most of the play out.
Old 04-30-2007, 10:09 AM   #21
Well, that is 100% to do with the existing parts that are broke / worn.. Fix that first, then determine whether you need a short shifter or not, imo.
Old 04-30-2007, 04:34 PM   #22
E30-dk
i bought a complete kit here in denmark for about 60$
and its about 75%shorter wandering on the shift... works great..
but how much shorter is the shift gonna be with z3 conversion..?
E30-dk is offline   Reply With Quote
Old 04-30-2007, 10:43 PM   #23
kapt_krickee
kapt_krickeet
kapt_krickee's Avatar
I've got a B&M short shifter...brand new in the box..was gonna put it into the ix but it got smashed..was gonna keep it for the next ride..but that one came with a short shifter
so..if u want it for what I paid for it.....(can't remember how much)
grey4door 325ix parts car !!SOLD!!
http://www.maxbimmer.com/forums/showthread.php?t=79123[IMG]
kapt_krickee is offline   Reply With Quote
Old 04-30-2007, 11:11 PM   #24
86coupe30
1990 325is
86coupe30's Avatar
and what price would that be 50 bucks?
Old 05-01-2007, 12:03 AM   #25
Wannabe
Northwood.
Wannabe's Avatar
mines cut.. i dont mind the throws.. i dont race, just liker low
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
Old 05-01-2007, 04:50 AM   #26
Willy
Willy's Avatar
so does anyone have the complete parts list for the z3 1.9 conversion so i can compare it to mine. wanna get this done.
from what i've heard RMP motors can do the work. but does anyone know if they can provide the parts as-well.
thanks.
Old 05-01-2007, 12:16 PM   #27
If you read any serious racing book, or talk to pros, they don't all believe in a short shifter anyway. The 1/10 (or less) of a second it saves you is totally lost if you miss one shift, which gets easier and easier to do as you give yourself less leverage. "Notchy" is bad, and could lead to missed shifts under tense situations.
Old 05-01-2007, 03:55 PM   #28
FuryriderX
cra.iX.y
FuryriderX's Avatar
thanks.
its actually in this thread linkie
but ill give the list anyways
Z3 ? SSK
1x . . . 25 11 1 434 148 - Z3Shift lever - $43.81
4x . . . 25 11 1 220 439 - Spacer Rings (two extra)
1x . . . 25 11 1 220 832 - Rubber Bearing sleeve (could be replaced with UUC Delrin Bushings, this is one of the most important parts)
2x . . . 25 11 1 220 379 - Circlips $0.50 (one extra)
1x . . . 25 11 1 220 600 - Nylon Shift Bushing - $4.00
if you want to do more work you can replace also:
25.11.7.801.309 - Gearshift Rod Joint
which may require all or some of the following
23.41.1.466.134 - Dowel pin
07.11.9.932.863 - Circlip (x2)
25.11.1.221.243 - O-Ring (x2)
21.11.1.220.199 - Spacer ring
25.11.1.203.682 - Tension bushing
also, you could replace the bitch clip, since you might break it taking it off
25.11.1.221.849 - Bearing Bolt
Im going to do the z3 1.9 conversion on my car, with probably the uuc delrin bushings, and all of the above parts as well. (i have an iX, so i need the bent shift lever) ill update if it doesnt take too long to get everything together.
Old 05-01-2007, 05:27 PM   #29
Willy
Willy's Avatar
sick. thanks alot Fury. thats pretty close to what i got too. missing a few bits.
i'm actually not looking to race or build a race car. my shifter is just really loose, in and out of gear. when i searched for solutions on the forums the upgrade seemed to be the way to go. not overly expensive and i could reduce the length of the shift rod which was i was looking at too.
any other hints and tips are appreciated.
thanks very much.
willy
Old 05-01-2007, 07:16 PM   #30
Jamil
Jamil's Avatar
Here's another link with part numbers:
http://www.bmwe30.net/cgi-bin/datacg...005&Section=11
Since you mentioned you have a sloppy shifter make sure you change all the bushings, clips, etc. I made the mistake of replacing just the shifter and not doing the carrier bushings also. The shift was much better after but there was still too much play.
I bought the UUC Delrin Carrier Bushings and will be installing them soon
Jamil is offline   Reply With Quote
