Old 04-24-2007, 08:27 PM   #1
951kid
Lightbulb Modified 1987 Porsche 944 turbo FS - $14,500 OBO
Car was purchased as a project car, over 20k in upgrade/rebuild has been put into the car. The car needs to be tuned with the new piggy back ecu.
It was salvaged in 1998, had a few owners since [thats why it was a good candidate - project car]. It is an American car = newer style steering wheel + dual side airbags. 1987 = late offset, stronger control arms, forged rods, etc.
Here's what Project 951 included:
project 951 included:
cross drilled crank - balanced
aluminum JE pistons balanced
Connecting rods balanced
new rod bearings
Darton MID interlocking sleeves
oil pan gasket
clutch fork bearing
stg2 clutchmasters clutch
fidanza flywheel
3 layer steel cometic head gasket
rebuilt head
new head studs
new starter
new clutch slave cylinder
new intercooler
rebuilt k27/6 turbo
new turbo water temp sensor [for turbo timer]
new catalytic converter
new cycling valve
new O2 sensor
new throttle position sensor
new balance shaft bearings
rebuilt steering rack
55lb per hour injectors with ballast resistors
new injector wires
adjustable fuel pressure regulator
zeitronix wideband o2 sensor [logging capability]
vitesse racing piggy back ECU
custom turbo inlet J-boot
new idle-air control valve
new cam tower cover bolts [actually more important that it sounds]
new exaust studs
all major hoses replaced
new coolant reservoir tank
new paint [3 yrs old]
new pagid brake pads & RBF 600 fluid
993 cup 3 turbo twist replica [street] Toyo t1s - 225/45/17 & 255/40/17
993 cup 2 OEM with toyo RA-1 used for 1 lapping day [track] 235/45/17 & 255/40/17
new front koni yellow adjustable shocks + alignment
Picked up another car - and i don't have time/$ to tune this with the mods i have purchased for the other car. Asking $14,500 OBO - comes with everything listed above. priced to move now!
please email at djazzy99@gmail.com or contact evenings 289-242-9652.
//OM Scorza Exhaust | ZCP/SSR | TC Kline | Hotchkis | Stoptech ST40 | OEM LED | //OM Scorza CSL Trunk & Diffuser | Ice Link | TFX Retrofit
951kid is offline   Reply With Quote
Old 04-24-2007, 10:01 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
wow. that thing is beautiful. i personally love the look of the porsche 944's.
GL with the sale!
Old 04-24-2007, 10:05 PM   #3
JUICY J CAN'T
propr'one's Avatar
So just to clarify, is this car rebuild now? Or does it still have a salvage title.
hid headlights
Old 04-24-2007, 10:19 PM   #4
951kid
no, it still has a slavage title. bump.
Old 04-25-2007, 10:36 PM   #5
951kid
bump
Old 04-28-2007, 10:47 AM   #6
951kid
saturday bump
