Old 04-23-2007, 11:18 PM   #1
new2bmw
e30 door tweeters
what size are the actual tweeter speakers? can they be removed from the mount so i can upgrade them? these are the tweeters in the triangular mounts behind the mirrors.
thanks guys
new2bmw is offline   Reply With Quote
Old 04-24-2007, 02:43 PM   #2
MGYVER
MGYVER's Avatar
tweeters
They are 1 inch and glued in tight.
I replaced my with Alpine's and they sound great !
MGYVER is offline   Reply With Quote
Old 04-25-2007, 02:17 PM   #3
paul christians
87325is///MR.EVIL
any 1" tweeter will work just fine,and to take the old out just cut them out...
87is325///2.7L..EVIL.....
Old 04-26-2007, 07:17 PM   #4
woofster
Did you guys wire your tweeters through a crossover? How is it set up from the factory?
woofster is offline   Reply With Quote
Old 04-26-2007, 07:56 PM   #5
paul christians
87325is///MR.EVIL
it is done though the amp,there for it is an 8 channel amp...
Old 04-26-2007, 09:50 PM   #6
FuryriderX
cra.iX.y
FuryriderX's Avatar
depends on what you want to do. the tweeters have their own passive crossovers that are attached to the door speaker; if you pull the speaker out you can see the capacitors and inductor coil on the back of the basket.
if you want to just replace the tweets then go ahead and do it; i just put a pair of clarion tweeters in with the stock tweeter wires, they work perfectly.
if your setting them up independantly of the stock system, then yes, you absolutely need a crossover or you will blow them up very quickly.
Old 04-27-2007, 11:35 AM   #7
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
when i get my blaupunkt shit ill be in touch with you to help me figure it out and put it in ok? if your down to help ahha
86coupe30 is offline   Reply With Quote
Old 04-27-2007, 07:13 PM   #8
FuryriderX
cra.iX.y
FuryriderX's Avatar
sure. you know where to find me.
(edit - 200th post! wheeee!)
Old 04-28-2007, 09:47 AM   #9
What? No it's not. The crossover is built into the mids in the kick panels.
Old 04-28-2007, 02:49 PM   #10
paul christians
87325is///MR.EVIL
^^^oops my bad,I was thinking of something diffrent at the time and just notice that I anserwed it wroug....sorry about that...when you do Xover for tweeters make sure it is 18db per octive.....
Old 08-30-2007, 12:01 AM   #11
new2bmw
speakers
ok, i have the premium sound system from an 89 325i that i am going to instal in my 84 318i. The only thing i plan on ading is my 300 watt 4 channel amp and a new pioner headunit and new wiring. how would i wire this up? so i need a crossover between the front speaker and the sail tweets?
Old 08-30-2007, 10:17 AM   #12
