Old 04-06-2007, 04:29 PM   #1
oldskool3
oldskool3's Avatar
removing entire subframe
Hey guys I was trying to replace my rear lines with SS lines and all of the lines are completely rusted to shit and while trying to remove one I cracked a line and it is now leaking. Anyways my question is has anyone removed the entire rear sub-frame all in one piece with trailing arms and everything. If so how heavy was it and how much of a pain in the ass was it.
I would like to replace all of the brake lines in the rear of the car and feel it would be an even bigger pain to do it while the subframe remains in the car.
I have removed one before but the car was sitting on it's side so it's not really a good judge of how hard it will be while laying on my back. Thanks
Jesse
Old 04-06-2007, 04:37 PM   #2
Soldo
Soldo's Avatar
I removed the rear subframe off my old e36 all at once. It was ****in heavy. The car was on a hoist but i used a engine lift to lower the thing. I would imagine the E30 one would be just as heavy if not heavier. Its a 2 person job for sure!
Keven Soldo
Old 04-06-2007, 04:38 PM   #3
BigD
the misanthropist
BigD's Avatar
Depends how much you remove. The subframe itself and the A arms weigh nothing. That changes if you leave the diff and brakes attached.
Old 04-06-2007, 07:13 PM   #4
oldskool3
oldskool3's Avatar
i would remove the diff/ brakes seperately and than remove the whole thing. I think I found away around it. I only need acces to the T above the rear diff. I am thinking I may remove it anyways to clean it up and Por15 the whole thing plus change the trailing arm and subframe bushings.
Only problem is I can't afford the Por 15, subframe or trailing arm bushings.
Old 04-06-2007, 09:24 PM   #5
tominizer
Also think about snagging a set of the IE camber/castor eccentric bolts for the rear trailing arms............ if you're digging in that deep.
Tom
Current : 2013 Mini Countryman JCW, 2007 Z4M Roadster
Past: '88 E30 M3, '69 BMW 2002 Ti, 2000 328i, Audi A6 TT, BMW X5 3.0i , Audi A4, Mini Cooper Clubman S 1.8T
Old 04-07-2007, 01:31 AM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
The T is $13 from the dealer. I'm in the process of re doing all the brake lines in the back, just did a patch job on the one that broke, going to do a proper job when i get the parts in.
Old 04-07-2007, 03:11 PM   #7
oldskool3
oldskool3's Avatar
Good to know thanks Axxe. Are you running a new line for the rear to the front? I am thinking about just running a rubber line from the hard line off the t to the line running to the front so I don't have to replce the whole line. I will replace it when I do my swap and have easier access to the brake master.
Old 04-07-2007, 03:17 PM   #8
Axxe
Axxe's Avatar
Do not run a flexible line unless you properly flare it and use high pressure fittings. In fact, don't use rubber lines, just flare it, use a union, and then attach the new line. This is brakes after all, it's high pressure and you don't want it to fail. I am going to run all new fuel and brake lines throughout the entire car, and bypass ABS (my abs unit is screwy).
Old 04-07-2007, 03:24 PM   #9
oldskool3
oldskool3's Avatar
I geuss i will flare the line than instead of running new all the way to the front for the time being. I really just want to get the car on the road as I have barely gotten to put any km since the b25 swap.
I would love to but I can't weld and unfortunately would have no idea on how to adjust the camber/toe in properly.
thanks for the help guys
