Old 04-02-2007, 02:15 AM   #1
88SuperETA
From the top (ENGINE)
Ok last month my sister got stuck in the mud in her neon. I went to pick her up in my car and bottomed out. i tore the arms loose on the cat back. well the next morning my car will only rev to 3k. not thinking it was the exaust I changed. FPR, PLUGS, AFM, FUEL PUMP RELAY, FUEL PUMP, FUEL TANK VENTILATION VALVE, COIL, AIR FILTER, F.I sensor, coolant sensor, adjusted valve's. still my car won't go past 3k unless i'm easy doing it. My car will go from 3k to like 2500 check engine light come's on it. I think it's the exaust. only thing's I got is fuel filter, tps, wire's and i'v pretty much replaced everything.
any help would be great!!!!
88SuperETA is offline   Reply With Quote
Old 04-02-2007, 02:46 AM   #2
Its NOT the exhaust...the car will rev just as well without it...very LOUD, but it will work! Done it many times! lol
Old 04-03-2007, 12:25 AM   #3
The Sly
The Sly's Avatar
I had a similar issue with a 89 IX that would not rev past 3000rpm and replaced all kinds of parts until i checked the cap and rotor and found the bolts on the rotor were coming loose to the point of losing them .
I redid the bolts on the rotor and voila ...
So you never know what it could be.
Good luck
The Sly is offline   Reply With Quote
Old 04-03-2007, 12:19 PM   #4
Slowered318
check your crank sensor and the wires connecting it.
02 sensor and wire as well
Old 04-04-2007, 05:22 PM   #5
Docherty
you may have knocked the internals of the cat loose and its plugging the exhaust wich could possibly cause that problem.
Docherty is offline   Reply With Quote
Old 04-05-2007, 02:58 PM   #6
88SuperETA
well i know the night it started the exaust was knocked loose. I unplugged the #6 wire and it quit until like 5k so i'm thinkin it's back pressure from the exaust and where's the crank sensor? and for the o2 sensor i unplugged it and still the same thing.
Old 04-05-2007, 03:00 PM   #7
88SuperETA
if anyone near deleware i'm at A.I DuPont hospital..or anyone live's in kentucky pm me if u wanna take a look i'll pay...my bimmer red.
Old 04-05-2007, 04:10 PM   #8
88SuperETA
oh yeah when i'm in netural it will go all the way to 6k w/o cutting out. just doe's the 3k when i'm in gear. The check engine light will come on to until it goe's down to like 2500rpms. i'm gonna check the rotar thing out and the cps hopefully it will solve it. If not i will move on to the exaust.
