Old 04-01-2007, 08:42 PM   #1
jamison67
E30 POWER
jamison67's Avatar
help to find oie and water temp fittings
I just bought an oil presuure gauge and a water temp gauge and i went to hook them up but the fittings that came with the kit dont fit for both the water temp and the oil pressure ,i live in richmondhill does anyone now the size of thread that it is and where i could buy the fittings from,one guy told me home depot
jamison67 is offline   Reply With Quote
Old 04-03-2007, 03:38 PM   #2
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Once upon a time
I needed fittings which could couple with the bmw auto tranny stock fittings, for a remote cooler. I went all over the place, even to a special hydraulics shop. None of them could get me anything.
as for the Water temperature and oil temperature stuff, remove a bolt from the system, or a sensor, and take it with you, so you can compare threads.
Best of luck, let us know how it goes, I wanna get some gauges myself..
Mike
Old 04-03-2007, 04:07 PM   #3
dgmorr
I believe the oil pressure fitting is M12x1.5. From that you can find one with an NPT female fitting which should fit something that came with your kit. You can order it here
http://fittingsandadapters.stores.ya...mettofemp.html
part# 32MM-12-2
For water temp you can get a barbed T fitting and cut into the line that goes from the thermostat to the TB. Get it as close to the Tstat as possible.
