Old 03-18-2007, 05:53 PM   #1
Muzikant25
rim/Tire fitment?
BMW 18" x 9" Alloy Wheel
5 Double Spokes -2001 bmw 7 series rims
tire Front: 235/50ZR18 Rear: 255/45ZR18
will this setup fit a 2002 bmw 530i ?
is the offset out too much ?
will the rear rub ?
Muzikant25 is offline   Reply With Quote
Old 03-18-2007, 06:31 PM   #2
TheMadChigga
TheMadChigga's Avatar
need to machine the bore to 74.1mm
and front should be 18x8, probally m-parallels.
it'll fit no problem, once you get the bore fixed.
Old 03-18-2007, 06:33 PM   #3
Muzikant25
what is the bore ? where and how much does it cost to get it machined ?
Old 03-18-2007, 08:01 PM   #4
TheMadChigga
take the tires off the wheels, I think they'll charge about $50 to bore it out per wheel.
or ish.
Old 03-19-2007, 09:37 AM   #5
Paul540/m3
BMW Individual
Send a message via MSN to Paul540/m3
Make sure its done right or there can be major issues after
Paul540/m3 is offline   Reply With Quote
Old 03-19-2007, 09:59 AM   #6
windsor318is
Nitrous Junkie!
windsor318is's Avatar
with that much hassle, you should pass on them and wait for the right fitment.
Old 03-19-2007, 10:52 AM   #7
TheMadChigga
sending the wheels to a machine shop isn't that much hassle.
any competend machine shop can put that on a lathe and bore it out, if its good deal then go for it, stock M-parallel are at least 3k brand new, that's IF.
Old 03-19-2007, 11:18 AM   #8
Big Chin
It should be fine when its bored out... unless they screwed up lol... And I don't know if there will be a rubbing issue on the front... 18x9 is fairly large for the fronts.. but you should try and check the clearance before you do it...
Maxbimmer FeedBack
Big Chin is offline   Reply With Quote
Old 03-19-2007, 02:21 PM   #9
TheMadChigga
18x9 is fine, people have fitted up to 285 up front.
Old 03-20-2007, 03:29 PM   #10
Muzikant25
sounds like a hassle to get them onto my 530
cost of the wheel set with tires $1200
then $200 to bore
then another $100 to re install tires
it all adds up
anyone else selling a similar set ?
Old 03-20-2007, 05:13 PM   #11
Paul540/m3
BMW Individual
Make me an offer on my set and we can take it from there
Old 03-22-2007, 11:53 AM   #12
Big Chin
Paul you should just put some winters on them and make your car a year round driver
Maxbimmer FeedBack
Old 03-23-2007, 10:07 AM   #13
Paul540/m3
BMW Individual
Already have winters beleive it or not, eventhough my car is barely driven in the winter.
