Old 03-12-2007, 11:43 AM   #1
bubsy12
bubsy12's Avatar
Send a message via ICQ to bubsy12 Send a message via AIM to bubsy12
1995 Dodge Avenger Built & Boosted
YEAR: 1995
MAKE: DODGE
MODEL: AVENGER BASE 5spd 4cyl
MILEAGE: 164,000km or so (2,500km or less on boost and rebuild)
Car has never seen the track/dyno pulls very strong, spins tire on the hwy @ 9-10psi... which it is set to right now, never seen higher boost (ENGINE BUILT TO HANDLE MUCH MORE). Body is it pristine condition for a 95, small 2"x2" spot of rust on passenger door. I'm at a loss for words but if you have any further questions feel free to PM me.
THE GOODS:
Interior:
-Sparco Speed Driver Seat (Black)
-Triple gauge A-Pillar Pod
-Autometer Sport-Comp A/F Gauge
-Autometer Sport-Comp Volt Gauge
-Autometer Sport-Comp Oil Pressure Gauge
-Autometer Sport-Comp Boost/Vac Gauge
-EGT Gauge
-ApexI Turbo Timer
Exterior:
-TC Spoiler TC1 Body Kit
-Catco HighFlow Catalytic Converter
-Magnaflow Exhaust
-Removed Resonator
-2.25" Mandrel Bent piping
Engine:
Rebuilt Head with P&P
-Crane Valve Springs
-Eaton PT Lifters
-Head Decked
-Aggressive Grind Stock Cams
-Ported and Polished Intake ports
-3 Angle Valve Job
Rebuilt Block with forged internals
-JE Pistons 8.6
-Total Seal Piston Rings
-Eagle H-Beam Long Rods
-Clevite 77 Main Bearing set
-Clevite 77 Rod Bearing set
-Melling Oil Pump
-Cylinder Walls Bored-Over and re-sleeved
-Knifed Crankshaft
-K&N Air Filter
-Accell Thundersport Ignition Wires
-Screamin Demon Coil Pack
-Walbro 255lph Fuel Pump
-Stock Fuel Injectors
-Vortech FMU 12:1 disk
-30lb Ford Injectors (Not installed yet)
-Vortech SFMU (Not installed yet)
Fully Rebuilt Tranny w/:
-Spec Stage 3 Clutch
-Aluminum Flywheel
-Neon 3.55 Final Gear mod
--- STAR STAGE 2 TURBO KIT w/ FMIC---
Turbonetics Stage 3 T3/T04e Hybrid Turbocharger
STAR 4 into 1 Cast Iron Turbo Exhaust Manifold
Turbonetics Evolution Wastegate
STAR Front Mount Intercooler (Polished Cast Aluminum End Tanks)
TurboXS Type-H BOV
Turbosmart MBC
STAR Mandrel-Bent Chrome-Plated Piping
STAR 2.5" Exhaust Down Pipe
STAR Wastegate Dump Tube
STAR Blue Silicone Couplers and Clamps
STAR High Pressure/High Volume Inline Fuel Pump
STAR Vortech Boost Dependent FMU
STAR Intake Air Filter Assembly
Map Sensor Bypass Valves
Stainless Steel Braided Oil Feed Line w/ Fittings
Oil Return Line Assembly
All Necessary Hardware and Fittings
All Necessary Hoses and Hose Clamps
All Necessary Gaskets
Apex-I Turbo Timer
Suspension:
-18"x8" MSR Style 107 rims
-225/40/18 Hercules G5000zr tires
-KYB AGX Shocks/Struts
-Maxspeed Coilovers
-Ingalls Camber Correction Kit
In Car Electronics:
-Eclipse 3402 CD Player
-MTX BlueThunder 50x2 Amp
-Pioneer 6x9s
-Pioneer 5-1/4s
-Power Acoustik 1100watt Sub Amp
-1-12" MTX Thunder 8000 sub
THE BADS:
-Very minimal exhaust leak where manifold meets head
-Very minimal oil leak from valve cover gasket
-EGR/PCV blocked off
I think thats about it, i'll post pics in alittle bit.
Asking $14,000obo CAN (11,950 USD), but am definately willing to negotiate
Reason for selling, need a new project to work on.
Contact by PM or call me @ 416-561-1138
Sean
2008 Toyota Rav4 V6 AWD Sport - Daily Driver -
www.SpoolnU.com - ALPHA. SIGMA. BOOST.
bubsy12 is offline   Reply With Quote
Old 03-12-2007, 12:23 PM   #2
piran21
piran21's Avatar
Wow...I'm surprised to see this! Is this an early April fool's joke? Bump for this man's pride and joy! Can believe it's here in the Classifieds. Awesome car.
P
GTADeal.ca
your one stop for group deals of the day
piran21 is offline   Reply With Quote
Old 03-12-2007, 12:25 PM   #3
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
I belive those cars are built at mitsubishi's asembly plant in usa, just not with turbo. Easy swap to use tallon or eclipse manifold.
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 03-12-2007, 12:28 PM   #4
bubsy12
bubsy12's Avatar
you are right about it being built non-turbo... as for easy swap of the manifold.. that is not correct, the talon/eclipse 4g63 manifold will not swap without loosing alot of other parts in the process.
Sean
Old 03-12-2007, 12:54 PM   #5
JUS_CRZN
JUS_CRZN's Avatar
Cool, not many people are doing this conversion. Its nice to see something different. G/L with the sale you have done alot of work to that car.
JUS_CRZN
Old 03-12-2007, 01:14 PM   #6
JMW
Pole busted to boosted.
JMW's Avatar
g/l saw the car at the show...looked cool man
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
JMW is offline   Reply With Quote
Old 03-12-2007, 05:00 PM   #7
v_bimmer
Jailbait FTW
v_bimmer's Avatar
a very nice car eventhough i dont like domestics!! but this is one is very nice!!! GL with the sale
v_bimmer is online now   Reply With Quote
Old 03-12-2007, 07:16 PM   #8
Chris de la Cruz
sex, drifting & punk rock
sean... sad to see the car go. can't wait to see the new project!
Its a lifestyle.www.coolkidsclub.ca
Follow me on Twitter! www.twitter.com/EuroDriftStar
Subscribe to my Youtube Channel: http://www.youtube.com/user/641215cruz
Old 03-13-2007, 03:59 PM   #9
Hound
V-Dub in da House
Hound's Avatar
Send a message via MSN to Hound
can't believe it sorry to see this leaving you Sean, really is a sick ride! Hope it goes to someone who will keep it looking good and not wind up going to a kid who would potentially put it in a tree.
Sean
07 GTI, Revo Stage II, 3" catless GHL exhaust, OEM R32 rear conversion, 17x9 + 17x11 215/45/17 all around on genuine BBS RS's, B&G RSII coilovers
96 Harliquin Golf
Hound is offline   Reply With Quote
Old 03-13-2007, 09:40 PM   #10
951kid
i've seen this car - very nice work and knowledgeable owner.
Bump for seller - this thing belongs on a racetrack!
//OM Scorza Exhaust | ZCP/SSR | TC Kline | Hotchkis | Stoptech ST40 | OEM LED | //OM Scorza CSL Trunk & Diffuser | Ice Link | TFX Retrofit
951kid is offline   Reply With Quote
Old 03-13-2007, 10:35 PM   #11
Damn Sean, didn't know you were such a celebrity.
I've watched this car transform from a funny-looking stock Avenger to the beast it is today, step by step. The build of this car took wayyyy too many long nights, as I got used to driving by at 2:00am and watching the guys adding new stuff every summer.
I don't even wanna know how much you actually spent on this car. In any case, $14k is a good deal.
Old 03-15-2007, 03:39 AM   #12
Trekz
sick car. How about you trade me for my 325i it can be you're next project
1995 E36 318is
Engine Mods: 94 M50 motor, Lightweight Flywheel, SACH clutch, UUC shifter, Electric Fan, Header and Full Exhaust, Magnaflow muffler, CAI, Racing Dynamics Chip
Exterior Mods: M3 spoiler ( Not installed yet), Projector Headlights, M3 mirrors.
Suspension Mods: Front Strut bar, Eibach spings, Billstein Struts.
Interior Mods: M3 buckets, Reverse Glow gauges, Momo steering wheel, M3 Shift Knob, M3 Headliner
Trekz is online now   Reply With Quote
Old 03-19-2007, 10:41 AM   #13
bubsy12
bubsy12's Avatar
taking offers... pm me #'s
Sean
Old 03-27-2007, 08:27 AM   #14
bubsy12
bubsy12's Avatar
bumpity bump, any reasonable offers will be highly considered
not looking to trade
Sean
