Old 02-21-2007, 01:30 AM   #1
b1mmer
Steering dull knock noise.
If I jiggle my steering wheel left to right when stationary I can hear a dull knock type noise coming from the footwell area, I can actually slightly feel it through the dead pedal.
Also from the same front wheel if I drive slowly over cats eyes on the road, the steering shakes a little.
Ive checked my tie rods for play but they seem OK. However with the car raised or on ground there is some 9-3 O'clock play on the same front wheel. I couldnt locate where the play was originating from, tried putting my hands over the bushes but to no avail.
Thanks.
b1mmer is offline   Reply With Quote
Old 02-21-2007, 08:27 AM   #2
E36is
'OldSchool..'
E36is's Avatar
inner tie rods most likely.. get the front of the car up, and get someone to move the tire side to side (9-3) and grasp the the boot cover end of the rod and feel for any play. If there is, then there is your culprit.
cat eyes??????
Old 02-21-2007, 09:17 AM   #3
Hasselhoff
Hasselhoff's Avatar
I agree with E36is - it sounds like your innner tie-rod ends.
Originally Posted by E36is
cat eyes??????
They're reflectors embedded in the centre and passing lanes in most roads in the UK. They're also pretty common in the rest of Europe too.
http://en.wikipedia.org/wiki/Cat's_eye_(road)
Hasselhoff is offline   Reply With Quote
Old 02-21-2007, 10:31 PM   #4
b1mmer
Thanks guys.
When I checked my tie rods briefly a week ago I did notice that they spin if grasped by hand, I think this is normal but there shouldnt be any horizontal play in them right?
Old 02-22-2007, 10:32 AM   #5
Hasselhoff
Hasselhoff's Avatar
Originally Posted by b1mmer
Thanks guys.
You're right, the rods should turn (with a little bit of resistance), but not have any hoizontal play. It's pretty easy to check, even with the car on the ground.
Do like E36is is saying and have someone sit in the car and turn the steering wheel side to side (it doesn't have to be much, just enough to get the wheels to turn a little). While they're doing that, grab the tie rod and see if you can feel any clunks or clicks. If either of the joint's (inner or outer) are gone, you should be able to feel a light clunk through the tie rod when the steering rack moves side to side.
At any rate, hope this helps.
