Old 02-14-2007, 07:14 PM   #1
ZiMMie
Educate me on S50 Cams.
If u were to upgrade an m50 cam to ones from S50's wat else need to be changed apart from the cams?
Does the lifters has to be changed too?
Wat else is needed for the swap?
#E36-S54 #CSLWannabe
Old 02-14-2007, 10:33 PM   #2
thinair
moderationistismingly
thinair's Avatar
All you need are the cams. I swapped S52 cams into my 328 a couple years ago, nothing else was changed, no issues. You CAN change out the springs, but it's not superly necessary.
Old 02-15-2007, 10:12 AM   #3
ScotcH
Software of course.
Old 02-15-2007, 03:25 PM   #4
thinair
thinair's Avatar
Software isn't really required. I've run my cams without cam specific software for a while now. Although it will boost some midrange torque with software that was more then likely lost with the installation of the cams.
Old 02-16-2007, 11:39 AM   #5
ZiMMie
thanx
wat other options do i have if i dont find M3 cams?
is there any aftermarket companies out there that makes performance cams for N/A m50 for a reasonable price?
Old 02-16-2007, 11:50 AM   #6
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Do you have a m50 vanos or non-vanos? For the non-vanos I'm pretty sure you can't put M3 cams on it.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 02-16-2007, 11:53 AM   #7
ZiMMie
its a vanos motor.
Old 02-16-2007, 12:24 PM   #8
^^flav you're right, but i believe there are RD cams for non-vanos motors.
Old 02-16-2007, 12:29 PM   #9
Dr. Flyview
"Mint"
I was just on understeer.com looking at the blue m3...and check this out:
Before the Schrick cams my M3 dynoed at 232.2 RWHP with 219.7 ft/lbs of torque. After the Schrick cams, new Conforti "cams" chip and 24# injectors the dyno numbers reached 242.3 RWHP and 228.3 ft/lbs of torque.
He got a mere 9hp and 9ft/lb of torque increase with all that?!
sold
Old 02-16-2007, 12:30 PM   #10
well flav, you have to ask yourself, what does he have done to that M3 to dyno at 240rwhp anyway?
different mods work together differently. Although i'd agree, 9hp, albeit 9rwhp, seems a small reward for 1200$ cams, and tuning.
Old 02-16-2007, 03:14 PM   #11
thinair
thinair's Avatar
For him to have 232rwhp, he's no where near stock already, stock is 195-205rwhp
Other cam options are non-m schrick cams, cat cams, etc. M3 cams are definately your cheapest option.
Old 02-16-2007, 08:10 PM   #12
uber e36
uber e36's Avatar
Zimmie - I'm doing the swap this spring. You can pick up S50 cams on Bfc for ~$300.
I'm also doing 3.5" intake path and 24lb injectors...
'95 325is
?02 C4S
Old 02-19-2007, 09:55 AM   #13
ZiMMie
unfortunetly there is nothing on there now.
Can someone confrim this, I read somewhere that, S52 cams will work in a M50 if i use the same cam trays. True?
Old 02-21-2007, 11:24 PM   #14
b_w.
i think with obd1 you need the software...the only reason you can get away with stock software with obd2 is cause of the adaptaion capacity of the ecu
b_w. is offline   Reply With Quote
Old 02-25-2007, 10:15 PM   #15
ZiMMie
Bump!
