Old 02-08-2007, 09:18 PM   #1
BritneyBMW
BritneyBMW's Avatar
Problems with heater
Hey everyone!
I have a 2003 330, my heat doesn't blow hot! Does anyone know what is wrong with it?
BritneyBMW is offline   Reply With Quote
Old 02-09-2007, 12:06 AM   #2
BmW1718
Send a message via MSN to BmW1718
check your coolant level do you have your switch to red lol lots of people don't put it to red . and check you coolant level . prob will fix your problem if not give me a pm
1987 325is Red Summer Car
1992 325I 4 door Winter beater )
BmW1718 is offline   Reply With Quote
Old 02-09-2007, 09:35 AM   #3
StikiGreenZ
StikiGreenZ's Avatar
Yeah there are two places to look at your heat settings, the digital one that controls ambient cockpit temperature and the analog dial in the center vent that controls the 4 vents near face level. I've always found it a bit tricky getting the car at a comfortable temperature, always a bit too warm or too cold!
BMW 645i - Black on Red
Old 02-09-2007, 01:54 PM   #4
BritneyBMW
BritneyBMW's Avatar
thanxx!
Old 02-09-2007, 06:08 PM   #5
BmW1718
is it fixed???? what did u do ?? switch ??
Old 02-09-2007, 08:57 PM   #6
windsorbmw
Pedal to the metal!
windsorbmw's Avatar
Mine was like that earlier, check your temp guage, if it is stuck or barely moves then 100% it is your thermostat that needs changing. I took mine to the stealer and got a decent price for the repair. the thermostat came as a whole piece witht he housing and everything installed/coolant top up came to 300 bucks.....now I am nice and warm in the car
windsorbmw is offline   Reply With Quote
Old 02-09-2007, 10:53 PM   #7
windsorbmw
Pedal to the metal!
windsorbmw's Avatar
so did u check?
Old 02-10-2007, 12:50 AM   #8
BmW1718
lol u have to change the housing with those thermostat there a one peice lol it just sounds good it comes with housing lol if you temp gauge stays a 1/4 it's your thermostat by the sounds of it the problem is fixed
Old 02-10-2007, 01:19 PM   #9
windsorbmw
Pedal to the metal!
windsorbmw's Avatar
Basically what I stated.....read
Old 02-11-2007, 06:58 PM   #10
BritneyBMW
BritneyBMW's Avatar
I took it to a mechanic and topped up the coolant and it was fixed. He said something was loose in the engine and it leaked out some coolant.
Old 02-11-2007, 08:04 PM   #11
windsorbmw
Pedal to the metal!
windsorbmw's Avatar
gr8....stay warm
Old 02-15-2007, 06:15 AM   #12
Daddy
Or you could be a dork like me and not know about the dial in the middle vents. They were on the "blue dots" and I was complaining about lack of heat... turned it to the "red dots" and voila heat!
The Dork.
Daddy is offline   Reply With Quote
Old 02-15-2007, 03:50 PM   #13
diezel06turk
diezel06turk's Avatar
i just had to replace me t start over the weekend.. costs 120 at da dealer...they charge too much for installation so i just changed it myself...
diezel06turk is offline   Reply With Quote
