Old 02-04-2007, 07:25 PM   #1
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
Send a message via MSN to Bimmerized
Heat Problem E36, please help!!
I have a heat problem. Idle blows cold air, then once reved up it heats up.
Charlie replaced the thermostat but still the same.
Could this be the heater core, or is there anything I can do cus I am freezin in my car??
Bimmerized is offline   Reply With Quote
Old 02-04-2007, 08:38 PM   #2
waterpump?
also, what does the temp gauge read? is the car not getting warm at all?
Old 02-04-2007, 08:56 PM   #3
Jon@Bimmersport
Jon@Bimmersport's Avatar
Hmmm, sounds like the heater valve is getting stuck. Your car isnt over heating, so I dont think it would be the new thermostat or even the pump. Maybe you were right...you should move up the street from us, let me know when your comming up ill grab a coffee for you again on the way to work.
Old 02-04-2007, 09:09 PM   #4
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
Is there a DIY for this somewhere?
I really dont want to drive all the way to Miss in this weather!
Old 02-04-2007, 09:28 PM   #5
Boots R
Boots, not boost
Boots R's Avatar
Have you topped up your coolant? when my coolant was low I had no flow.
Old 02-04-2007, 09:51 PM   #6
Jon@Bimmersport
We just did his thermostat so we re-filled the coolant, we would have noted a leak right then and there...no car leaves our shop with a half done job. You should know that Kev!
Well the heater valve is a bitch to do in the cold, unless u like squeezing inbetween your manifold and master cylinder in -15degrees.
Old 02-04-2007, 10:13 PM   #7
Boots R
Boots, not boost
Boots R's Avatar
lol I was just unsure how long it had been since the Thermostat was replaced. If he had mentioned that it was replaced recently, i wouldn't have even asked that question.
Old 02-05-2007, 12:50 AM   #8
No offense jon, but it seems like the heat still doesn't work. That's just a job not done at all.
It could probably be air in the coolant lines, but i doubt that's the case.
Old 02-05-2007, 09:37 AM   #9
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
JB, I know man, it's the valve, maybe stuck like you said, and I will be there maybe next week sometime. I get heat but not like on idle, and once start moving, or rev just a bit it's nice and warm.
Old 02-05-2007, 11:16 AM   #10
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
My car is the same- no real heat until you push it even when the engine is at normal temp. Check this http://www.maxbimmer.com/forums/showthread.php?t=66769
Old 02-05-2007, 02:16 PM   #11
Stephanie
Stephanie's Avatar
my guess it that its the heater control valve, as mentioned above... do u smell any coolant inside the car once you get the heat going?
Black Sapphire Metallic | Coral Red | Brushed Aluminium | 6MT | ZSP | ZPP | PDC | Bluetooth
Shadowlines | Matte Grilles | Aero Lip | BMW Performance Pedals | Smoked Reflectors | LLumar Tint 40%
KW V2 | VMR V710 | Super Sports | BMS JB4 | BMS DCIs | HPF Intercooler | UUC EVO3 SSK | UUC RK7 Shift Knob
Stephanie is offline   Reply With Quote
