Old 02-02-2007, 04:00 AM   #1
Shtuey
Removing Window Tint
Hey guys,
What's the best way to remove window tint in this cold weather we've been having?
Shtuey is offline   Reply With Quote
Old 02-02-2007, 09:45 AM   #2
Nascar318is
Nascar318is's Avatar
From what I have been told from a tinter is take the window off the car and use a razor blade and what not to peel the tint off. Once that is done you have to soak the window in some sort of solution over a period of a few hours to get the gunk off the window that was left behind from the tint. It's a PITA to do, if you can I would wait till spring to do that, or bring it to a tinting place and have them do it. If it's tint all around, you want to remove, be very careful when taking the tint off of the rear window, you don't want to damage the defroster or radio antenna in the glass.
Old 02-04-2007, 09:52 PM   #3
^^bingo.
removing tint is really easy, razor blade a corner (press the blade flat against the glass, so the entire sharp surface is against the glass).
Try to keep it in one peice, pull it off.
For the rear, dont use a razor. Use your fingernail, dont scratch against the heated elements, and use a ammonia/ethanol solution to loosen the glue if you're having trouble.
Old 02-06-2007, 10:09 PM   #4
2002guy
Send a message via MSN to 2002guy
i have dont this amny times, ive used air intake cleaner, water and soap, and also gasoline to remove the glue it is a PITA but if thats what you wanna do its worth it.. on average it would take me about 4 hours to do an decent car properly
Sposered by: M-Tricks Autosports
My Cars:
1974 "2502" m20 2002
1989 735i
1982 vw rabbit
2002guy is offline   Reply With Quote
