Old 01-25-2007, 09:44 PM   #1
simsima
2nd gear, floored...mmmm
Interior fan growling/noisy
Hey all,
It was brutally cold today and I'm not sure if the weather had anything to do with this. I drove the car normally for 20 minutes. I was idling in it for 10 minutes or so with the engine running and the fan started to get really noisy.
Kind of a growl, with clicking, and rubbing. I turned the climate control off and started chaging the settings manually. The faster the fan spun, the quieter the noise got, even taking into consideration the extra air noise. It didn't seem to matter which vents the air was going through.
I went in for my appointment and once I got back and started the car it was still happening. As soon as I started driving and the engine was reving over 2000 RPM, the noise seemed to go away.
I'm definitely going to take this in to get checked out, but would like to have some ideas before I do. So any help would be appreciated.
Thanks in advance.
2000 328i sedan
simsima is offline   Reply With Quote
Old 01-25-2007, 11:56 PM   #2
diezel06turk
diezel06turk's Avatar
i got a 01 and same issue...but i assumed it was bcuz it was too cold
diezel06turk is offline   Reply With Quote
Old 01-26-2007, 03:46 PM   #3
FastM3
is dreaming of ///M's
FastM3's Avatar
If I recall correctly, I think it is because it's too cold, unless this noise is really out of the ordinary type loud then you got a problem.
FastM3 is offline   Reply With Quote
Old 01-26-2007, 05:18 PM   #4
Marky_mark
Detailing Specialist
Marky_mark's Avatar
It could be your blower motor is on its way out you may need to replace it but get your car checked out to make sure
Old 01-27-2007, 04:13 AM   #5
diezel06turk
when the car warms up ...everything goes back to normal..i hear no noise but my exhaust
