Welcome to!
Old 12-15-2002, 01:38 AM   #1
Mostly absent
e36_freak's Avatar
Send a message via ICQ to e36_freak Send a message via MSN to e36_freak
HELP!!! e36 deck installation
i'm just wondering.... because the e36 came with the stock amp that runs the speakers......
now i just got a new deck...
i've been told by M5FANATIC that there's no way i could run 2 amps (stock & deck) because the deck has a built in amp. it'll either fry the stock amp or the amp on the deck.... he says that it's not possible to run the deck and the stock amp...... just wondering if anyone else did..... and did anything happen....
i think it should be okay.....
any help is gratefull..... thanx
Life isn't about how many breaths you take, but the moments that takes your breath away.
Giving the government money and power is like giving a teenager whiskey and an M5.
e36_freak is offline   Reply With Quote
Old 12-15-2002, 03:26 AM   #2
Jon@Bimmersport's Avatar
im guessing it will work...bimmersport has stock amp and speakers with a deck, i think gamite has it done too...same with Sith on his 92 will have no problem..i think M5Fanatic has been off maxbimmer so long that he forgot everything
Old 12-15-2002, 05:10 PM   #3
Soldo's Avatar
hey Mike, ya it works fine, i've done it with my E36 and i've had no problems so far, but also i assume that my car has a better AMP, cause with me E36 320i it was a 4spkr. car, and the deck would sometimes sound shitty when it got a bit TOO hot, could be cause i had a MP3 deck, or something to do with my amp, not sure yet, but in my 325i i've had NO problems up to date!!!
PM if you got anymore questions!!!
Old 12-17-2002, 07:06 AM   #4
Send a message via AIM to rayz Send a message via Yahoo to rayz
i believe, if you run speaker leads from an aftermarket deck (with built in amp, maybe 45x45) into your oem amp, it will cancel out the power from the deck. a friend of mine had it done. they also bottom mounted 3 way 6x9's in the rear shelf, they actually removed the tweeter from the 6x9 and mounted it higher (closer to the grille). sounds way better than the tiny nokia stock speakers in the rear.
i just remembered. my alpine is running through the oem amp too. weird how the stock e30 sound system has only 2 channels to begin with. they totally rewired it 4-channel,and hooked up my stock speakers to the oem amp
rayz is offline   Reply With Quote
