Old 12-22-2006, 12:55 AM   #1
Redster
Stuck In The 6th Gear
Redster's Avatar
Adjusting headlights
Is there a way to "even out" xenon headlights, so instead of that 'Z' pattern (where the light on the right side goes further ahead) both sides are even?
"You wanna make moves on the streets? Do not have any attachments, do not have anything in your life you are not willing to walk out on in 30 seconds flat if you spot the heat around the corner."
Redster is offline   Reply With Quote
Old 12-22-2006, 01:06 AM   #2
Gamite
Gamite's Avatar
you want the z pattern. Its there to light up signs on the side of the road. if you had a straigt line, the light would not reflect back.
I used to have a straight pattern on my old US spec elipsoids, it actually makes a difference having the Z.
www.gamite.net
Old 12-22-2006, 02:58 AM   #3
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
You have to open them up.
The cutoff is made by a thin metal plate inside the headlight that blocks the light at the top to make the pattern. All you got to do is find something to modify the plate to your desired pattern- you can get creative here, you don't necessarily have to go flat all the way accross.
I noticed that after putting HID's behind the e-code depos, they were blinding people like crazy even at the lowest setting...so I modified mine, using an old metal blind slat and some all temp super glue, and made it so that top half of the tick is blocked slightly...so I now have the regular cutoff, the tickup, and then another plateau.
Another thing I've seen done is to flatten out the cutoff on the driver's side light only, keeping the regular cutoff on the passenger side to lightup the signs and whatnot. One light will look brighter than the other at certain angles though.
Old 12-22-2006, 03:29 PM   #4
EstorilM3
People do damnest things here
But, why just not use some duct tape on the outside of the lens?
EstorilM3 is offline   Reply With Quote
Old 12-23-2006, 09:54 AM   #5
spooner_dee
Has no idea whats goin on
spooner_dee's Avatar
if you cant duck it, **** it.
Old 12-23-2006, 10:03 AM   #6
abc12
what kind of car is it ne ways, most of them are easily adjustable, just turning a screw back and fourth will do the trick......
abc12 is offline   Reply With Quote
Old 12-23-2006, 12:20 PM   #7
Redster
Redster's Avatar
It won't because, as M3ti Compact said already, Z pattern is created by a metal plate inside pass side headlight.
