Old 12-11-2002, 05:40 AM   #1
ctchirica
How much heavier is an M52 motor than a M42?
Trying to figure out how much car will squat after i swap the M42 for an M52?
ctchirica is offline   Reply With Quote
Old 12-12-2002, 12:13 PM   #2
webbie
Hi.. the engine will weigh about 40kg more if you use the M52 with iron block...
Take a look at this link.. useful info. on weights etc...
http://www.unixnerd.demon.co.uk/enumber.html
webbie is offline   Reply With Quote
Old 12-13-2002, 01:59 AM   #3
ctchirica
Thanks for the info! The link was cool too. Thanks!
Old 12-15-2002, 08:36 PM   #4
E30 Stu
Send a message via AIM to E30 Stu
I am calling total BS on that chart. They say that an M42 is 20kg HEAVIER than an M10?!
The M50 is about 60pounds heavier than an M42.
Stuart McHenry
E30 Stu is offline   Reply With Quote
Old 12-16-2002, 12:42 AM   #5
ctchirica
So how much lower will my e-30 sit after the swap? 60 pounds heavier would be what? about 1 in. lower?
Old 12-16-2002, 03:25 AM   #6
Dave 325i
Why wouldn't the M42 be heavier? Or just not by 20kg?
Dave 325i is offline   Reply With Quote
Old 12-17-2002, 11:56 PM   #7
E30 Stu
M42's are 3" shorter than M10's, have lighter blocks, lighter heads, lighter everything.
With an extra 60 pounds, it might sit .2-.5" lower, definately not 1 full inch.
Stuart McHenry
Old 12-18-2002, 05:19 AM   #8
ctchirica
That means with the 1.6 front drop of the Intrax springs, I will be at about a little over 2 inch drop after the M52 goes in. This should be alright on 17/7.5 with 225/45/17.
