Old 12-12-2006, 02:59 PM   #1
Furious
BMW again.
Furious's Avatar
tire question
usually i wouldnt ask this question but im a bit confused and dont wanna pony up the money to get the wrong sizes.
what is the maximum size i can run in terms of rubber on my car?
-rim size 8.5x18 offset-35mm
-suspension- bilstein sports/ H&R sports
-fenders not rolled yet
-current size 225's
-im trying to see if i can get my tires up to 245's is this possible?
thanks
Old 12-12-2006, 03:25 PM   #2
Soldo
Soldo's Avatar
245's should fit easily, with a 32mm offset, and the fact that you got a coupe. I don't see it being a problem!
Don't E36 M's come with 245's in the rear? Whats the offset on most M rims, 32-35mm no?
Keven Soldo
Old 12-12-2006, 03:46 PM   #3
E36is
'OldSchool..'
E36is's Avatar
^^Mark: I believe Ant118 is rolling on 18's with 255 at the rear, and he is rubbing large, so my guess is probably 245 max for 18's.
Old 12-12-2006, 05:31 PM   #4
mirek
mirek's Avatar
225 on 18's? that's small
Old 12-12-2006, 06:37 PM   #5
8.5" wide and ET35 is pretty aggressive. You'll have trouble with anything wider than 225 without rolling/pulling. That said, just rolling them should be able to let you run 245/35/18's.
Soldo, 8.5" wide rear M wheels are up at ET41, and can still rub non-M fender wells with 245's.
Old 12-12-2006, 07:09 PM   #6
kuds
I take pictures
kuds's Avatar
I had 245's all around on my old 318is, and it would rub slightly in the front when turning the steering wheel, but nothing major.
davinaplusdaniel.com
wedding photography
kuds is offline   Reply With Quote
Old 12-12-2006, 07:39 PM   #7
Soldo
Soldo's Avatar
I had no idea that E36 M's had different fender wells. I just thought that coupes had bigger fenders than sedans! My bad on the offset too, i thought it was in the high 30's
Keven Soldo
Old 12-13-2006, 02:18 AM   #8
That's a sign your wheels had a higher offset than Mark's; they were rubbing the inside well, he's looking at issues with the bodywork.
Old 12-13-2006, 03:51 AM   #9
Furious
BMW again.
Furious's Avatar
yeah the 35mm offset was what was recomended by bbs for my car. shrug, who would have though i would want wider. i was gonna throw 235s on to begin with but got the 225s for such a good price.
im gonna try to get the fenders rolled, maybe shave hte inner edge and run tires with no lip, should get me some results.
Old 12-13-2006, 07:10 AM   #10
Mark i'm running 235/40/18 on my rims (et35, 8.5wide) and i do (did) rub a bit till rocco fixed up the fender. If anything, run 235/35/18's, that's an odd tire size though./
If you want, before you order them, we can slap my rims on your car and see if it works.
Old 12-13-2006, 10:26 AM   #11
Justin e36
Justin e36's Avatar
Roll your fenders, you should be fine with 245's. 255's will take a bit of imagination to get working without any rubbing.
Old 12-13-2006, 11:35 AM   #12
windsor318is
Nitrous Junkie!
windsor318is's Avatar
doesnt super m3 run 255's on his e36 m3?? i think he had his rear fenders pulled though. can you run a 245 on a 8" wide rim????
Old 12-13-2006, 12:34 PM   #13
Justin e36
Justin e36's Avatar
I'm running 255's on a 8.5" rim, didn't pull my fenders. They're rolled though.
Old 12-13-2006, 02:20 PM   #14
His fenders were cut and pulled really nicely; definitely not a quick/cheap job.
And yeah, 245's on an 8" rim is possible. Wouldn't handle better than a 235 though.
Old 12-14-2006, 12:46 PM   #15
Furious
BMW again.
Furious's Avatar
thanks guys for the input, i might even run a staggered tire setup 235's front and 245's in back. im gonna need traction so who knows ill see what i can do for trying to fit 255's,but probably not.
