Old 11-30-2006, 08:07 PM   #1
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
Oz wheels
I wanted to see what you guys think of these wheels?
I'm planing on running 17x8 rims 225/45/17 Font and 245/40/17 Rear.
Any comments?
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 12-01-2006, 09:36 AM   #2
thinair
moderationistismingly
thinair's Avatar
The Ultraleggera's are great rims from what I hear. They're cast, but light and strong, and not really that expensive. They also offer a lot of caliper clearance if you ever decide to swap to larger calipers.
Why are you planning to run staggared?
Old 12-01-2006, 10:04 AM   #3
JUS_CRZN
JUS_CRZN's Avatar
I am planning on running willwood brakes this winter, and the car needs more
traction in the rear.
JUS_CRZN
Old 12-01-2006, 10:08 AM   #4
thinair
thinair's Avatar
What car is it?
Old 12-01-2006, 10:13 AM   #5
JUS_CRZN
JUS_CRZN's Avatar
1998 328i S/C, 3.23diff, Ltw flywheel, 3.2L motor.
JUS_CRZN
Old 12-01-2006, 10:16 AM   #6
thinair
thinair's Avatar
you might want to look at a wider rim then, like 8.5", and run 255 all around. At least you're car won't understeer as much.
With the way e36's and e46's are setup, I always advise against a staggared tire setup, narrower front tires always make the car understeer more. Unless this is a show car, then disregard the above.
Old 12-01-2006, 10:21 AM   #7
JUS_CRZN
JUS_CRZN's Avatar
No, its not going to be a show car.
I'm building it for personal enjoyment and hopefully lots
of driving schools at Mosport.
JUS_CRZN
Old 12-01-2006, 10:39 AM   #8
thinair
thinair's Avatar
Then in my opinion you really should look into something wider then 225 up front, and avoid staggarded if you're planning on hitting the track.
Old 12-01-2006, 11:18 AM   #9
JUS_CRZN
JUS_CRZN's Avatar
How about 235's all around. Im worried about rubbing.
JUS_CRZN
Old 12-01-2006, 11:32 AM   #10
thinair
thinair's Avatar
That's what I run now on my car, and it's a great size for an 8" rim, you can potentially have straight line traction issues in the first and second gear, well, first gear is a given...especially with a blown 3.2L
Also you have the option of rotating the tires with a non-staggarded setup.
Old 12-01-2006, 11:34 AM   #11
JUS_CRZN
JUS_CRZN's Avatar
Thanks for the advice...
Are you running 40's or 45's
JUS_CRZN
Old 12-01-2006, 11:42 AM   #12
thinair
thinair's Avatar
235/40R17 all around.
I notice that with a 245/40/17 the sidewalls start to bulge a bit on an 8" rim.
Old 12-01-2006, 11:46 AM   #13
JUS_CRZN
JUS_CRZN's Avatar
Brand of tires?
JUS_CRZN
Old 12-01-2006, 11:57 AM   #14
thinair
thinair's Avatar
Toyo T1R's
Old 12-01-2006, 12:24 PM   #15
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Rotating tires is crucial, especially with track use, where the fronts wear the outsides and the rears wear in the insides.
