Old 11-23-2006, 06:10 PM   #1
mirek
mirek's Avatar
whining
I get a whining (alternator whine?) I regrounded my battery to the chasis, same thing, not as bad as before, but it's still whining. What else can I do?
Old 11-23-2006, 08:20 PM   #2
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Maybe check your RCAs if your using an amp, I've had this problem before, one of the ends was unscrewing and getting interference.
Old 11-23-2006, 08:45 PM   #3
mirek
mirek's Avatar
i've disconnected my amp and same problem
Old 11-24-2006, 02:15 AM   #4
paul christians
87325is///MR.EVIL
it is a ground loop problum,how do you have your ground from your amp and deck done???and allso check your power wire from your battery as well....
87is325///2.7L..EVIL.....
Old 11-24-2006, 04:14 PM   #5
mirek
mirek's Avatar
the power and ground to my deck are using just the regular wires from oem radio
Old 11-25-2006, 10:53 PM   #6
paul christians
87325is///MR.EVIL
it sounds like your RCAs are getting power waves thought them so move them...............
Old 11-27-2006, 01:53 AM   #7
Jim .E.
E90 n00b
Jim .E.'s Avatar
sounds like the same problem in my friends Envoy.
He ran the RCA's down the left side of the envoy and the power/ground down the right side that way there was no interference
Old 11-27-2006, 02:33 AM   #8
Gamite
Gamite's Avatar
are you sure the sound is comming from your speakers?
I had my diff bearings go and they whine just like the speakers do. I turned my radio off and the sound was still there.
www.gamite.net
Old 11-28-2006, 03:54 PM   #9
mirek
mirek's Avatar
learn to read pplz, the amp is GONE, it's just the deck now . And shielded RCA's do not interfere with power anyways.
Yeah, the sound is definately coming from all 4 speakers, fluctuates with RPM, buzzing\whining.
Old 11-28-2006, 07:57 PM   #10
BMW03
We had that happen to a system that we hooked up a couple of weeks ago, and it was because we ran the rca's, the power wires, and the speaker wires all down te same route. We just rewired everything seperate and that solved the problem. Sounds like you have something else going on though.
BMW03 is offline   Reply With Quote
Old 11-29-2006, 12:12 PM   #11
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
lol. Its just the deck!
Maybe re ground your deck yourself or follow the ground wire for the deck to where it terminates and make sure its good.
Stanceiseverything.com
Old 12-01-2006, 08:52 AM   #12
paul christians
87325is///MR.EVIL
^^^maybe the deck.......I would go thow the wiring of this set-up....
