Old 11-19-2006, 08:49 PM   #1
elguapo84
m-tech 1 mounting hardware questions
Hey guys, I'm about to make an order throuh bav auto for the m-tech 1 mounting hardware, and have some questions...
Here are the links to the diagrams, so you can visualize what parts I'm talking about:
Front airdam:
http://realoem.com/bmw/showparts.do?...& hg=51&fg=15
Sides:
http://realoem.com/bmw/showparts.do?...& hg=51&fg=20
Rear apron:
On the front airdam Bav auto doesn't carry the left and right covers (that go under the spoiler) or the brackets that seem to attach to them...are these parts necessary?
Here is a comprehensive list of what I think I need to order from Bav Auto
Front:
15 HEX BOLT WITH WASHER M6X 16-Z2 2 07119915042 $0.28
07 FLAT WASHERA 6,4 2 7119931044 $0.22
06 CLAMPING BOLTM TECHNIC 6 51111919151 $1.14
16 HEX NUT M6-Z2 8 51451868108
17 HEX HEAD SCREW ST6,3X16-C-Z11 1 07119916965 $0.28
18 BODY NUT ST6.3-10 1 07129925719
Rear:
13 FASTENER M TECHNIC ? 51121932230
14 HEX NUT M6-Z2 ? 51451868108
(there was a question mark under quantity, so I counted the number of holes and assume that I need 17 of each of these- is that correct?)
07 BRACKET M TECHNIC 1 51121953905 $2.23
08 HEX HEAD SCREW ST4,2X16-C-Z2 2 07119916922 $0.11
09 BODY NUT 4,2-1-ZNS 2 07129901644
15 RIVET M TECHNIC 4 51711937627
04 SYNTHETIC STRIP M TECHNIC 1 51121942083 $8.37
05 FOIL LEFT M TECHNIC 1 51711926201 $6.70
05 FOIL RIGHT M TECHNIC 1 51711926202 $5.91
(are these strips and foils necessary? What is their purpose...do they seal up the seams or something?)
Sides:
05 CLAMP M TECHNIC ? 51711919149 $0.78 (Question mark on quantity - I assume I need 4 of these, do you know?)
08 EXPANDING RIVET M TECHNIC ? 51111976050 $0.84 (another quantity question)
06 GROMMET 6 51131934160 $0.28
09 EXPANDING RIVET 4 51161881149 $0.27
10 CLAMP 4 51711934949 $0.95
11 SHEET METAL SCREW B4,8X19 4 51711939302
12 HEX HEAD SCREW ST4,8X19-C-Z2 2 07119916949 $0.22
07 ADHESIVE TAPE 3000MM 2 51711976999 $18.97
07 FOIL 1835 MM 2 51712239899 $8.93
(these are pretty expensive - Do I absolutely need them...will a cheaper adhesive work? what do you recommend?)
They no longer carry the drilling stencils or drilling jigs (do I need these?)
Basically, I just need to know if any of those parts are unneccesary so I don't spend more money than I need to...all of those parts added up were quite expensive so I'm trying to minimize these costs. I really appreciate all your help.
An unlucky E30 I came across in Rotterdam, Holland
elguapo84 is offline   Reply With Quote
