Old 11-19-2006, 04:47 PM   #1
Swerve
///Maquina
Swerve's Avatar
Cabin Air Filters
So do you really have replace them every so often? What's the harm if I just leave the one I currently have in there? I've never changed it...
The reason I ask is because this one's on ebay cheap: http://cgi.ebay.ca/Cabin-air-filter-...QQcmdZViewItem
95 Madeiraviolett/Dove Grey 325is
///M3 body | Painted kidneys | Hartge spoiler | DJ Autos+DDM HID, DRL delete, clears
Hartge Nova 3+Kumho Ecsta SPT / Hamann HM2+Kumho Ecsta ASX | Bilstein Sports, H&R Sports, KMAC plates, RE RSMs, Racing Dynamics sways, M3 RTABs | M3 Front Brakes
M3 Exhaust | Autothority chip | Cosmos v2+K&N | NGK Iridiums | E46 M knob | clutchstop | woodgrain delete | /////ALPINE, PPI, MB Quart
Swerve is offline   Reply With Quote
Old 11-19-2006, 04:59 PM   #2
JUICY J CAN'T
propr'one's Avatar
They filter air. So new filter = cleaner air. Also, think about it. If the filter's clogged, you're gonna get that much less air.
swap it. Price of part isn't an issue, they can be a hassle to change.
hid headlights
Old 11-19-2006, 05:08 PM   #3
Quack
Wheelman
Quack's Avatar
I replace them once to twice a year, if you never replaced yours, take it out and take a look, it would be grey or black, that is what you are breathing in, and as Propr'one already mentioned when it gets clogged up you also get less air flow through the air vents
Quack is online now   Reply With Quote
Old 11-19-2006, 05:41 PM   #4
vadim321go
vadim321go's Avatar
change it man! its not that hard and there is a good diy on it. and there is no need to take off the glovebox to do it. trust me the hardest part for me was getting the old filter out as there was so much dirt holding it in. make sure to have a vacuum nearby.
Proud owner of a 95 325i
Old 11-19-2006, 05:41 PM   #5
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
I took about 2 cups of leaves and twig bits out of my heater ducts when I replaced the filter on my 318. I was wondering why there was no heat. Yes, the filter was black too.
thinair is online now   Reply With Quote
Old 11-19-2006, 07:00 PM   #6
europrince
changing cabin air filters shouldn't be an issue
Old 11-19-2006, 10:20 PM   #7
v_bimmer
Jailbait FTW
v_bimmer's Avatar
do you guys have a diy link??? im interested in changing mine
Old 11-20-2006, 01:17 AM   #8
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
OMG...
I never changed the filters since the car was new (1995, so 11 years), so I went to the dealer, and they wanted ****ing $90 for them...so I told them to **** off, i'll figure out something.
The plan was to take the old filters out, clean them, and reinstall it. Easy.
Well, it took ****ing 2, yes 2 hours to get the damn firewall off- not because I couldn't find the screws or anything- because everything is jammed in there so tight, I pratically had to use all my weight to pull the firewall off...I finally got in there, and there were two completely filthy black filters- jammed with so much shit, it looked like a flat filter even though it was bellowed. Anyways, I tried cleaning the filters, but ended up destroying them- the things are unservicable- don't even bother trying.
I ended up cutting out the old filter element and retrofitting on material from a home HVAC filter. Took me another hour to fit everything back in.
I'm going to have to get the real ones eventually because I don't think the household filter will standup to an automotive application. Going to have to take everything apart again...what pisses me off is with so many people working at BMW when they were designing this car, that didn't someone say, hey- this filter, which needs changing regularly, SHOULDN'T be this hard to get to.
Old 11-20-2006, 01:21 AM   #9
thinair
thinair's Avatar
$90?!?!? Holy shit, I just bought one and it was $45. And I'm sure i could have gotten cheaper if I hadn't gone to the dealer.
Old 11-20-2006, 02:24 AM   #10
JUICY J CAN'T
propr'one's Avatar
they're like 14$ online
hid headlights
Old 11-20-2006, 03:03 AM   #11
Justin e36
Justin e36's Avatar
In my e39 there are two cabin filters, they're located in the engine bay just like the intake filter element. Lift up the clips, lift up the filter, drop a new one in, and snap the clips down. 20 second job.
I picked up my filter from Canadian Tire, it wasn't more than $40 I'm sure.
I don't know if they changed the design in the TI's, but in my car it was extremely easy to do, only took a few moments.
Old 11-20-2006, 09:17 AM   #12
rico328i
Here you go. Mind you this is for an E36 328...I'll double check to see if it's the same for you 318/320/and 325 guys. Wrote this up a while back.
Hope it's helpful. I just checked...all e36's use the same filter.!
http://www.maxbimmer.com/forums/showthread.php?t=45466
Old 11-20-2006, 02:02 PM   #13
kuds
I take pictures
kuds's Avatar
If you are going to have a started installed, apparently it's in the same area. I just had mine done last week, and the guy didn't charge me anything extra for putting in the new filter.
davinaplusdaniel.com
wedding photography
kuds is offline   Reply With Quote
Old 11-20-2006, 03:15 PM   #14
thinair
thinair's Avatar
It's great that you didn't get charged for the filter install, but the starter and the cabin filter aren't really anywhere near each other.
Old 11-20-2006, 06:11 PM   #15
M3ti Compact
The 318ti's don't use the same filter...they got two smaller ones which are accessed by taking out a panel in the firewall under the hood.
The other E36's are accessed through the passenger compartment.
