Old 11-18-2006, 01:48 AM   #1
therock
Top Gear
therock's Avatar
19' on E46
Hi, i just put these massive wheels on my car .. 03' 320i
front : 19x8.5 /235/35/19
rear : 19.9.5 /265/30/19
then i lowered it .. now i have MASSIVE rubbing .. what can i do ..? thanks for the help!!
therock is offline   Reply With Quote
Old 11-18-2006, 08:55 AM   #2
Justin e36
Justin e36's Avatar
the first thing you should is put your old wheels on until you have this problem resolved.
then get your fenders rolled, possibly need to pound them out a bit. may need to work on your suspension too.
Old 11-18-2006, 10:24 AM   #3
oafguy
West Side Forever!
oafguy's Avatar
Send a message via MSN to oafguy Send a message via Yahoo to oafguy
Just get the fenders rolled. I had the same setup on my 02' 330ci and it was fine after rolling. Just remember this.... No Air Bags, No Switches, No Fat Bitches..... You'll be fine!!!
oafguy is offline   Reply With Quote
Old 11-18-2006, 04:57 PM   #4
therock
Top Gear
therock's Avatar
Sorry i forgot to mention that i already had my fenders rolled. and it did **** all ... pardon my french. this guy from a performance shop told me to get blisten shocks .. he says there 35% more stiffer then factory ... would that do the trick? another option is getting fender flares on the rear only .. but wouldnt the body rust because of that afterwards?
Old 11-22-2006, 02:49 AM   #5
therock
Top Gear
therock's Avatar
help .... anyone?
Old 11-22-2006, 09:27 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
What springs did you put in?
Old 11-23-2006, 12:43 PM   #7
cisco911
9.5 is too wide for the back of the E46 sedans....no matter what offset you run. I think the coupes have alittle more room than the sedans which allows for the 9.5 width.
Old 11-25-2006, 02:13 AM   #8
therock
Top Gear
therock's Avatar
i went with the rennsport lowering springs. also would fender flares fix the problem?
Old 11-25-2006, 06:20 AM   #9
R_JAY
Has the world for ransom
Just out of curiosity, what's the offset?
Old 11-25-2006, 12:24 PM   #10
Understated
7th Gear [SMG III] Member
Understated's Avatar
wow 265s in the back of a non m? those are some aggressive tires!
Understated is offline   Reply With Quote
Old 11-25-2006, 12:28 PM   #11
PedroBMW
Hooked on Boost
PedroBMW's Avatar
WOW 19 foot rims!!! (just picking on the thread title )
hey can you post a pic of the rear wheels on ur car?
http://www.foldingtrailers.ca
Old 11-25-2006, 12:50 PM   #12
Soldo
Soldo's Avatar
DAMN, you beat me to it!
I think the important question here is what offset are you running on these wheels? Do M's ever run 265's in the rear, and they have flared fenders.
Keven Soldo
Old 11-25-2006, 01:15 PM   #13
R_JAY
265 can work on a coupe. I know because I have them on my car which is also lowered. You can see a small pic in my sig. The offset on my rear wheels are pretty high though (+47). I do get the odd rubbing when I go over a dip at speed but my fenders aren't rolled yet.
On a sedan it's pretty hard to do because the rear fenders aren't as wide.
Old 11-25-2006, 01:19 PM   #14
Soldo
Soldo's Avatar
Ya, i figured if they can fit, then it has to be the offset.
Keven Soldo
Old 11-25-2006, 04:36 PM   #15
windsorbmw
Pedal to the metal!
windsorbmw's Avatar
Just what I wanted to ask.
I have 18x8 in the front and 18x9 in the rear. Now I am also lowered on KONI suspension kit...(yellow shocks and bluish springs). I have minimal rubbing until I hit a dip or like today I had a 100lb passenger in the rear seats and .....dam did I hear rubbing when I turn corners.....if she is sitting on the right and I turn left I will hear the rub and vice versa. Fenders are not rolled........no one in Windsor knows what rolling the fender means !
Also running 225/40/18 on all four rims.....not my choice bought them like this.....stretched in the rear....
Mind you that this setup was off an E36.
Anyone else have inputs?
As stated:
-Minimum rubbing with no rear passengers
-rubbing with passengers.
-Anyone in Windsor on this board that know some shop that rolls fenders?
windsorbmw is offline   Reply With Quote
