Old 11-16-2006, 04:21 PM   #1
Junior_dimez
BMW E30 Interior Water Leak
The carpet inside of my 1987 325i BMW on the front diver side is always soaking with water, does any one know where its coming from?
Junior_dimez is offline   Reply With Quote
Old 11-16-2006, 04:27 PM   #2
Is it water or coolant?
You can usually tell by the smell.
If its coolant its most likely your heater core.
If its water, it could be clogged sunroof drains or even worst a whole in the flooring.
Old 11-16-2006, 05:11 PM   #3
Striker
Turbo Ready
Striker's Avatar
Elephant trunk drain blocked. Look where the battery stand is in front, passenger side behind exhaust manifold, you will see it against the firewall.
This drains the water from the HVAC motor housing. Just squeeze the flat side and look at what comes out.
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
Striker is offline   Reply With Quote
Old 11-17-2006, 12:33 AM   #4
dueceman
the real answer
if you really want to know..i mean really? you need to pull your carpet..
dueceman is offline   Reply With Quote
Old 11-17-2006, 12:50 AM   #5
Striker
Turbo Ready
Striker's Avatar
No need to unless you have a rust bucket. Wet floors can only come from a few well known sources.
Found them on more that 15 e30's without pulling carpet.
Is the floor below rusted out? Is this happening when parked or driving?
If while driving check to see if the big floor plug beneath is there or not.
