Old 11-15-2006, 10:33 PM   #1
Seyar
Seyar's Avatar
Speakers aren't working need help
92 325i
i just put a deck and there is no sound so then i hooked the speakers directly to the deck to check if they were working and they were fine so i don't know why there is no sound when i hook it up to a harness.. if any body can help me that would be great.
Seyar is offline   Reply With Quote
Old 11-16-2006, 10:59 PM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
does it have a factory amplifier? some stock audio systems have a small amplifier built into them - you have to provide some sort of turn-on power to it before your speakers will work.
Old 11-16-2006, 11:10 PM   #3
Boots R
Boots, not boost
Boots R's Avatar
I had the same problem, but i still had Radio.
Do you have Radio and no CD?
Old 11-19-2006, 12:41 AM   #4
Seyar
Seyar's Avatar
where is the ampilifier located and i don't think i have the radio either but ill check on that
Old 11-19-2006, 01:41 AM   #5
Boots R
Boots, not boost
Boots R's Avatar
On mine, it is on the left hand side of the trunk, if you are looking into the trunk. There is a carpet lining aorund your trunk, you have to peel it back, to reveal this:
That big black square to the left is your rear speaker. The black box to the right is your amp.
Old 11-19-2006, 05:49 PM   #6
Seyar
Seyar's Avatar
ya i found the amp but how do i provide some power to it and how do i know if there is power coming to the amp.. sorry i don't know much thanks for your help guys
Old 11-19-2006, 06:58 PM   #7
FuryriderX
cra.iX.y
FuryriderX's Avatar
ok you bought a wiring harness for the new deck, right? often there's a blue/blue-white wire in it, that is described as the 'amp turn on wire'. look on the back of the harness to see if either of those 2 wires has a corresponding wire in the stock harness. if one or both of them does, then try turning the car to acc. and jumping one of those blue wires to +12. if you get sound, then great! wire that wire to the amp turn-on wire of the new deck. if it doesnt work, try with the other wire.
Old 11-20-2006, 08:12 AM   #8
Seyar
Seyar's Avatar
thanks alot guys its working now i jumped the blue wire to turn on the amp.. once again thanks for all the help
Old 11-20-2006, 10:10 PM   #9
FuryriderX
cra.iX.y
FuryriderX's Avatar
no problem. glad it all worked out!
Old 11-22-2006, 06:17 PM   #10
paul christians
87325is///MR.EVIL
OK,if you have wired in the speakers from deck to the hearnes you are taken power from one and in to the other.....BOOOOOM.....
87is325///2.7L..EVIL.....
