11-14-2006, 01:41 PM
#31
Car: S54
Originally Posted by static
Also I know that Gleb plans to make his E30 a track dedicated and i'd bet he'll spring for R-comps on it or at least ultrahigh-performance summers. What I said is true for those tires - go do research if you don't believe me.
Go to tirerack and choose the size 225/45r16, then check off 3 checkboxes: extreme, max and ultra-summers, how many hits? 2
Then go do the same for 225/50/15, how many hits? 8
which one is higher? need i say more?
Your source is flawed. Tirerack does not carry Toyo, Falken, or Hankook; these are some of the best aggressive tires available, and every single one of them offer at least 1 top-end tire in 225/45/16.
Street tires I like in 225/50/15:
KD
G-Force Sport
R-S2
T1-R
Street tires I like in 225/45/16:
KDW
FK-452
R-S2
T1-R
Also, Gleb wants at least 225's; wider than 225 in 15" is very difficult to find, 245/45/16 street tires as well as R-compounds are plentiful, and will bolt right onto an E30 (with fender work).
11-14-2006, 02:40 PM
#32
Car: E30 brilliantrot
i stand corrected then
11-14-2006, 05:09 PM
#33
Car: 88 M6, 85 325es (M50)
hey Raph, you make me blush, thanks for the flowers!
back to the brakes.
I have not run into any brake issues with my M50 powered E30 with normal OEM Rotors. I have tried slotted, ATE, Brembo and still always return to the OEM blanks ... good enough and cheap so I dont care if I have to replace them 3 times a year.
For pads I use most of the time Hawk HT10 (track pads) front and rear or GrandSport GS3.
Stainless steel lines, ATE fluid and Brake ducts is a must.
This setup is good enough for me to keep up with the faster guys on the track, no fading issues at all, very good feel and balance to the car.
I am locking up ocationally, it happens, but this is only because I have left the braking point to late (has nothing to do with swaybars or camber ...)
Oh, I use Toyo RA-1 (R-comp) tires in 225/50/15.
Klaus
85 325es
CASC-OR Regional Auto-X Series 2009 and 2010 1st place in D/Mod
Ontario Time Attack Series 2011 1st place in SGT2
11-14-2006, 05:52 PM
#34
Originally Posted by Gleb
With heat/dust shields removed, Carbotech pads, Motul 6 brake fluid and proper bleeding I still overheat them when it's hot outside.
interesting... what are the symptoms? mushy pedal or stiff pedal and "no brakes" feeling ?
if first - supposed to be the fluid, if second - try good sloted rotors to remove gasses.
11-14-2006, 06:13 PM
#35
Turbo Ready
Car: Turbo Charged 87 BMW325is E30 and 2002 BMW325i E46
Klaus
Just the truth Klaus, just the truth. I left you a reply on the German thread, let me know what you think. We can email or call.
Cheers.
Raph.
SPEED AND POWER IS NOTHING WITHOUT CONTROL,
THANK HITLER, BMW HAS ALL THREE
11-15-2006, 09:41 PM
#36
E30 M20
Car: 1987 325i
I may not be swapping after all.
called UUC yesterday, and was told "definitely in 30 days something should be ready for the E30". I will give them till Jan 1, 2007.
Also was talking to Lee (Massive), I think that his kit is also something to consider.
11-15-2006, 09:59 PM
#37
Turbo Ready
Swapping is allot of work, no doubt. The BBK should be more than enough.
11-18-2006, 01:25 AM
#38
E30 M20
Car: 1987 325i
Jay, are you saying that with 245/45/16 I will not have any speedo or gearing problems?
11-20-2006, 04:44 PM
#39
Car: S54
Speedo will be closer to correct than it ever was, gearing will be 2.9% taller (negligible).
