Old 11-01-2006, 12:12 PM   #1
beater audio Q's (kriston, paul, check in)
Ok so the sound system in the beater sucks (surprised?)
Good news is i pulled some stuff out of the bmw before i stored it.
Have a great headunit, and a sub.
More importantly, i have an amp. 4 channel, 500 watts RMS.
Here's my question. Obviously i'll hook up the headunit, and wire up the sub and the amp. But (i'm assuming) a 1989 accord doesn't have a stock amp.
So i'd like to replace the cabin speakers (most are blown anyway)
So i have 100 watts RMS coming out of the amp for the cabin channels. I'm pretty sure that's not a lot.
Should i set up just a L and R speaker?
Or can i do FL,FR,RR,RL?
and just make RR, FR, and FL,RL wired up to the same output?
In whichever case is true, what speakers should i get? they HAVE to be cheap, i refuse to spend real money on a honda. If you got used ones lemme know. However cheap speakers can be found on ebay, please just let me know what i should be looking for.
(has to be able to play somewhat clear reasonably loud, doesn't have to be blaring, just something to take my mind off the fact i'm driving a honda)
thanks guys!
Old 11-01-2006, 02:58 PM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Does your sub run off the 4-channel amp? As in, do you bridge two of thm to run the sub, and use the other two for speakers? I'd do it L/R, both left speakers running off the same channel, and both right speakers running off another channel. This begs the question, how is this amp @ 2-ohms? You're going to be wringing it out if you run the sub and internal speakers off of it (it will get hot fast), depending on model of course.
Old 11-01-2006, 03:21 PM   #3
paul christians
87325is///MR.EVIL
OK.HONDA do not a stock amp,so you can run your 4ch into a 3ch just no fading,you ch 1-2 to the front only,ch 3-4 bridge and the rear of the deck,the amp may get warm but it will not hert it at all,just turn the gain to 8 o'ckock and you are done.......and to answer to TOMs idea here and not a good idea to,WHY, well it is running a 2ch amp mix/mono,I would 4ohms on the amp only.......but if was a H/C amp than yes .....
87is325///2.7L..EVIL.....
Old 11-01-2006, 03:51 PM   #4
its a lightning audio striker 500.4
(rockford fosgate components i think)
400watts RMS bridged for the sub
then there's two channels, left and right for cabin, 50 RMS each.
i think that's at 4ohms, not sure about 2ohms
Old 11-01-2006, 08:09 PM   #5
$500bimmer
ivan, run 1 and 2 channel for your fronts. and 3 n 4 bridged for your sub then for your rear speakers run it of the head unit. u will have more front stage but its your winter beater. thats the way i would run it for my beater...
Old 11-01-2006, 08:14 PM   #6
Axxe
Axxe's Avatar
Okay, I was assuming he didn't have a built in amp in his head unit. I don't (anymore)
Old 11-01-2006, 08:15 PM   #7
$500bimmer
u dont anymore?....
Old 11-02-2006, 12:20 AM   #8
dan you know more about the audio system in my car than i do. I think i have like 20 watts RMS per channel out of the HU.
Also, tomek, about the amp overheating, its a 500watt amp, right now powering a 150 watt sub. It should do ok
Old 11-02-2006, 01:02 AM   #9
$500bimmer
honestly that will be fine for your rear speakers. and for the amp you could only be puttin out 150 watts of power to the sub and its a 1000watt amp. but if you have ur sub at 1ohm and the amp only goes to 2ohm it will heat up. to much resistance
Old 11-02-2006, 01:06 AM   #10
i dont know what any of that means. lol
you got some used speakers you wanna sell me dan?
Old 11-02-2006, 01:07 AM   #11
$500bimmer
lol what size do u need?
Old 11-02-2006, 04:19 AM   #12
Axxe
Axxe's Avatar
Originally Posted by $500bimmer
u dont anymore?....
Internal amp burned out. And now only one pre-amp output works. She's toast
Old 11-02-2006, 05:24 AM   #13
umm size. lets see
probably anything around 4 1/2 - 5 1/2 inches.
I have no problem taking a hacksaw to it to make it fit. I'll measure tomorrow
you still have that crazy cheap hookup on remote starters? i know like 5 people who want em, me included
Old 11-02-2006, 10:24 AM   #14
paul christians
87325is///MR.EVIL
what year is your beater IVEN??to be on the safe side of things 5.25 in the and back,1 10"sub in a sealed....there is braket for the fronts that can be remade of 1/8 MDF for a 6.5,and I would put a 4 or 5.25 in the back for fill..
Old 11-02-2006, 03:07 PM   #15
BMW03
Cheap rig for remote start, humm can someone get me the wiring on that or something.
BMW03 is offline   Reply With Quote
