Old 01-29-2002, 11:00 AM   #1
DunDan
Rust!
Hey guys I just did a DIY rustproofing yesterday.
Use either:
Rust Check - red (more oily to flow into crevasses)
Rust Check - green (thicker foam doesn't drip)
the above from Cantire or
Gutter guard (home depot)
I used alot Rust Check red to allow it to flow into all areas
Areas to cover:
Door panels bottoms (drain holes). Spray rust proofing into all drain holes or if you are inclined to take apart all the door, even better.
Trunk lid (2 drain holes) drainage gutter and bottom trunk edge (under latch trim). This is the infamous rusting area.
Hood/windshield drainage gutters
B-pillar corners
Rear fender wells
Rear shock towers and bracket inside the trunk (i didn't bother with the inside)
Sunroof
Rocker panels (back of front tires)
Exhuast welds
Try to do it on a clean car or you will be protecting the dust and dirt from your next carwash but be warned that you will have have overspray all over the car and will drip all over your driveway or garage.
DunDan is offline   Reply With Quote
Old 01-29-2002, 01:33 PM   #2
ronin
Hey DunDan,
How do spray the sunroof without getting the stuff on your head liner?
Thx,
Ronin
ronin is offline   Reply With Quote
Old 01-29-2002, 04:43 PM   #3
DunDan
Ronin,
Just place a good sized piece of old cardboard as a deflector up to the inside of your sunroof opening and spray from the outside.
Try not to do it when it is very windy outside or inside your garage.
