Old 11-28-2002, 03:38 AM   #1
e30_325_s52
e30_325_s52's Avatar
Send a message via ICQ to e30_325_s52 Send a message via AIM to e30_325_s52 Send a message via Yahoo to e30_325_s52
need some help on car audio
help me on this..some things i dont still dont understand yet...
lik
1000-Watt Bridgeable Amp with Built-In Crossover and Internal Cooling Fan — KAC-929
Stereo or bridged mono output; 460 watts x 1 in bridged mode; 230 watts x 2 @ 2 ohms; 150 watts x 2 @ 4 ohms; tri-way capable...so it means i could put one sub wit 460 watts and the rest for lik 6x9 or wha?..thx for the helpo
e30_325_s52 is offline   Reply With Quote
Old 11-28-2002, 03:40 AM   #2
e30_325_s52
heres anthor one...
AG1000 Amplifier - AG Series
Specs
2 x 250watts @ 4 ohms
2 x 450watts @ 2 ohms
1 x 900watts @ 4 ohms Bridged
Frequency Response: 20Hz - 20kHz
S/N Ratio: 90dB
...telll wha it means..i know some but i know i forgot
Old 11-28-2002, 04:12 AM   #3
Slowered318
It means you have a 2 channel bridgable amp. it will olny run subs or mids/highs not both without dumb external crossovers.
You have a lot of options on what you can run. this amp will power 1,2,3,4,6,or 8 subs.
here are a few suggestions:
900 watts (bridged) to one 4 ohm sub
500 watts to two 4 ohm subs
500 watts to one DVC (twin 2 ohm coils) in stereo
900 watts (bridged) to two 2 ohm subs (rare)
I would suggest you run one 4 ohm sub with the amp bridged. bridging makes the amp more efficiant and it will put out more power.
Old 11-28-2002, 04:16 AM   #4
Slowered318
BTW. very few amps can handle a load of 2 ohms bridged so i don't suggest you try it.. i've cooked my amp doing that!
The lower the ohms the more current required from the amp.. so a 1 ohm sub would reqire almost 4 times the power of a 4 ohm sub.. and poof up goes your amp in smoke
Frequency Response: 20Hz - 20kHz? don't worry about it.. it's pretty much standard. 20hz is the lowest frequency you can hear, 20khz is the highest frequency you can hear. that's just saying that amp will prduce any frequency you can hear
S/N Ratio: 90dB? again don't worry about it... i don't think your building an audiophile system
THD? is total harmonic distortion is usually measured at rated power 20hz to 20khz.. high quality amp run less then .02% THD.. D class amps built to run subs are usually around .05% to .2% THD. the less THD the better because it sounds like ass
good luck
Old 11-28-2002, 04:56 PM   #5
e30_325_s52
good luck
so wha would u do if u wanted two 12's or somehtin bigger lik a 15's
Old 11-28-2002, 08:42 PM   #6
Slowered318
yeah i would say run 4 10's, 2 12's or one 15"
4 mid level 10's about $150 each would sound amazing if you can afford them. 15's usually sound lose and dirty.. 12's are a nice blend of mid bass and low bass (good for Hip hop). 10's hit hard in the mid bass (great for dance) but 4 of them would give you more low bass then one 15"
Old 11-29-2002, 12:58 AM   #7
e30_325_s52
i just wasnt sue bout amps and shit...but i would put 2 12's in
Old 11-29-2002, 04:25 PM   #8
e30_325_s52
and wha are some good 12's?...pioneer TS-W3041C?
Old 11-30-2002, 12:10 AM   #9
Slowered318
Pioneer licks A$$
JL, Alpine, Kicker and Beyond audio make the best subs
Beyond audio X-one's
Old 11-30-2002, 12:54 AM   #10
e30_325_s52
Pioneer licks A$$
i wanna get a dvd/nav combo wit the screen and all...then add a tv tuner and antenna to watch tv...do u think that will be tite
Old 11-30-2002, 09:33 PM   #11
Slowered318
Not really.. i've looked into it before it's 70% mark-up and it's really not very usefull unless you plan to spend a lot of time sitting in a parking lot watching tv and movies. I would be a nice toy but i wouldn't install any A/V equipment untill you have a nice sounding stereo already.
A/V navigation system with stock speakers and bmw tape deck.. haha now that's ghetto
Old 11-30-2002, 10:30 PM   #12
e30_325_s52
[BA/V navigation system with stock speakers and bmw tape deck.. haha now that's ghetto [/B]
ya that would be ghetto...first u gotta get lik two 12's and the rest
Old 11-30-2002, 11:36 PM   #13
Lennon
Send a message via ICQ to Lennon Send a message via MSN to Lennon
Hey slowered! Shizzle ma nizzle eh!
Hehe
1990 735iL under construction.....
Lennon is offline   Reply With Quote
Old 11-30-2002, 11:50 PM   #14
Jase
twisted beyond reason
Jase's Avatar
probably the best bang for your buck would be 2 12' JLW0's ( they take almost nothing to power) at 4 ohms and like a 500 watt amp. I have seen some sweet 6 channel amps( soundstream stuff like that) power the whole car. don't run more than 1 amp unless you want to buy a cap or a bigger alternator.I agree with slowered about the Nav..leave it for now. Big $$ for a toy. You are better off to get a multimedia deck without a screen and get the screen after. You can always mount it in the the dash. get some nice components for the front and some decent rear fill and subs.
good luck
Old 12-01-2002, 12:48 AM   #15
e30_325_s52
good luck
i was thinkin bout two 12's and some mid's and tweeters in front....then goin wit the video shit after....and u think only 500amp is good?
