Old 10-10-2006, 06:28 AM   #1
E46er
UUC Pullies
Just installed the uuc pullies...but I'm running through a small problem here:
1) When I shift @ redline there is "belt skipping" kind of noise comming from the engine bay. But, at normal shifting there is no noise, only at redline
2) I just took out my cdv too...does that have to do with anything with the pullies going faster and as a result making that noise?
Thanks.
2005 Sparkling Graphite E46CI
E46er is offline   Reply With Quote
Old 10-11-2006, 02:30 AM   #2
E46er
anyone with uuc pullies and took out the cdv experiencing the same problem?
Old 10-11-2006, 08:38 AM   #3
SpoolinS6
SpoolinS6's Avatar
how many clicks on the car ???
maybe the belts are old / possible or just dried out
2000 Jetta tdi Bagged
1995 Audi S6
HI BOOST
Old 10-11-2006, 01:03 PM   #4
E46er
No the belts are new...since they came with pullies.
Old 10-11-2006, 02:18 PM   #5
330ci05
330ci05's Avatar
i have them and no problem....maybe you didn't put them on right, or something...
330ci05 is offline   Reply With Quote
Old 10-11-2006, 04:13 PM   #6
Jon@Bimmersport
Jon@Bimmersport's Avatar
its just your driving
Old 10-11-2006, 06:20 PM   #7
Furious
BMW again.
Furious's Avatar
what type of "belt skipping" noise is it? chirping? how long does it last for? did you do any other work on the car? i.e.-something that would have gotten coolant on the belt? have you checked your tensioner pully? maybe it was near time for a change and you may have not noticed because not everyone rips to redline every day so often.
Old 10-11-2006, 06:36 PM   #8
E46er
The noise is kind of weird ...it's more of a squeeking noise....and the noise is only there when I hit redline, but then when I shift gears it goes away because my rpm goes lower but then it makes that noise all over again on redline. And I think the tensioner on the e46 is hydraulic, doesn't that mean it will self adjust?
Old 10-11-2006, 06:41 PM   #9
E46er
It's not my fault that I like to push the car...and get back to work and stop posting on max like every 2 seconds
Old 10-12-2006, 12:43 AM   #10
Furious
BMW again.
Furious's Avatar
that does not mean it cant fail. id get your trusted mechanic to diagnose this problem as it could be a few things but all can lead to serious problems like the belt snapping because of some sort of small harmonic problem on one of the pullies etc.
Old 10-12-2006, 02:21 AM   #11
E46er
Yea, I give up ...I definetly have to get it checked by a mechanic. Thanks
Old 10-13-2006, 02:16 PM   #12
Shark
Shark's Avatar
where did you get your set of UUC pullies?
Shark is offline   Reply With Quote
Old 10-13-2006, 11:06 PM   #13
E46er
UUC themselves.
Old 10-13-2006, 11:41 PM   #14
Shark
Shark's Avatar
how much did you end up paying for everything (duty, shipping etc.)?
Old 10-14-2006, 04:29 AM   #15
E46er
Just go to the UUC website and you can figure it out from there, depending on the shipment etc.
