Old 10-08-2006, 12:27 PM   #1
Hibbing
SVS PB12-Plus/2 Subwoofer
Mint condition without a scratch. The ultimate deep bass, movies subwoofer. This will fill almost any size room with thunderous bass.
$1250.
Once in a while you encounter a product that simply excels in the value-for-dollar category. The PB12-Plus/2 is just such a product and as such comes with a strong buy recommendation if you’re in the market for a sophisticated floor shaker.
Be prepared to make the effort and take the time to properly set up this sub in your listening space.Because you have in the PB12-Plus/2 a product capable of dissipating substantial amounts of power into your listening space, the architecture and construction of the walls, ceiling, floors and other room features such as fireplaces and so forth will play a roll in your final listening experiences. If anything within earshot of the PB12-Plus/2 has a fundamental resonance within the sub’s range it will find it with surprising efficiency. Integrating it with your listening room and the rest of your system will take time, but is well worth the effort. I found doing so essential to getting the top-flight performance the PB12-Plus/2 is capable of delivering. Once done, get ready to have a LOT of fun with this sub.
SVS PB12-Plus/2 subwoofer
- Twin 12" SVS designed/built custom Plus woofers
- Full-featured 900 watt BASH digital amp
- Built-in, flush-mount amp configuration
- Down-firing with integrated SVS base-plate
- Compliant floor mounts, low center of gravity
- Three patented 4" high-flow flared ports.
- Assembled and tested by SVS in its Ohio factory
- Extra heavy-duty detachable 8 foot power cord
- Variable 16Hz, 20Hz or 25Hz tuning
- Size: 19" wide, 26.5" tall and 28" deep. Weight: 140 pounds
- Frequency Response: +/- 3dB to 20hz anechoic (4-5Hz deeper in-room response typical)
Hibbing is offline   Reply With Quote
