Old 09-28-2006, 10:25 AM   #1
Bliss
Administrator
Water/Alcohol injection
Anyone using this?, and what's your take on it?
For maXbimmer decals, please email info@maxbimmer.com
Old 09-28-2006, 11:46 AM   #2
Furious
BMW again.
Furious's Avatar
not using it yet. but will be sometime next year. i know that Fab is running it, and Paul was before he parted his car.
i find for FI it to be a very usefull mod, especially with superchargers, heatsoak is one the two major killers for supercharger users. water alcohol helps cool the charge restoring your power. for the turbo guys WI is great for retarding detonation. i have yet to read anything about stock cars using it and having any substancial use for it.
than again maybe your hinting onto what your next project might be Bruce
Old 09-28-2006, 11:59 AM   #3
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
It's usefull in disipating the heatsoak and doesn't run out as fast as some of you think. Mine last up to a month.
Sickbimmer is offline   Reply With Quote
Old 09-28-2006, 12:05 PM   #4
Blades
Your opinion is to long
Blades's Avatar
where would anyone get a system or the fluid (if mixed on your own what percentage)
-=[ BL/\DES ]=-
Old 09-29-2006, 02:18 AM   #5
Bliss
Administrator
When using it...does it inject manually?, or automatically when a certain temperature hits, or both? just doing some research on it.
Old 09-29-2006, 03:33 AM   #6
From aquamist website:
"Which Aquamist will suit my car?
All our kits are stand alone systems, it can be fitted to any turbo or supercharged engine.
We have three versions of water injection system.
System1s is triggered by boost only, the trigger point is determined by an adjustable pressure switch installed in the manifold (3-30psi).
System2s comes with an electronic controller (MF2), mappable between 2000-9000 RPM at 1000 intervals, load signal is either supplied by an adjustable pressure switch or a MAP sensor (not supplied) for a true 3-D mapping, water flow is progressive with pressure. The water line is pre-pressuised (adjustable between 4-8bars) at start up, flow quantity is regulated by a solenoid valve via MF2.
System2c is designed for users with their own custom ECU, mainly for racing cars. System comes without electronic controller.
Apart from effectively cooling the inlet charge, water's main contribution is predominately used for in-cylinder cooling and detonation control. Once the detonation is under control, the boost can then be increased further to achieve more power gain. "
Old 09-29-2006, 04:33 AM   #7
Bliss
Administrator
Thanks propr'one.
Fab, how is the AA one triggered?
Old 09-29-2006, 04:15 PM   #8
paul
when u hit boost
you mix it urself (real cheap)
Also bumps up octane a bit
I still have my kit forsale it was used for 3 mounths
paul is offline   Reply With Quote
Old 09-29-2006, 06:00 PM   #9
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Thanks propr'one.
I has a on/off switch and when in the on position it's activated by boost. About 3/4 psi.
Old 09-29-2006, 08:11 PM   #10
$500bimmer
paul did u get my pm?
Old 10-07-2006, 01:08 PM   #11
Bliss
Administrator
Thanks for the info
Old 10-07-2006, 02:26 PM   #12
JMW
Pole busted to boosted.
JMW's Avatar
yee...my kits not gunna come with this
but it does with the kit for the e46
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
JMW is offline   Reply With Quote
