Old 09-19-2006, 10:47 AM   #1
02-330ci
02-330ci's Avatar
A/C Problems
i hav a problem with my 02 330ci, when the car is first started it will coool well from all vents but as it warms up, the center vettnss increase intemperature until they are about 15 degress warmer then the outer vents. i evacuated and recharged to spec. pressures look normal and are ok, i already replaced the condenser. PLZ HELP
Photobucket - Video and Image Hosting
02-330ci is offline   Reply With Quote
Old 09-19-2006, 11:16 AM   #2
cisco911
if t he outer vents are still blowing cold, then it has nothing to do with your AC system. Its probably the flap in the vents that switches from the cold vent to the hot air vent is not closing all the way and as the car warms up, warmer air is flowing through the middle vents.
Old 10-16-2006, 09:08 PM   #3
GRIDLOCK
if the outer vents are still blowing cold, then it has nothing to do with your AC system. Its probably the flap in the vents that switches from the cold vent to the hot air vent is not closing all the way and as the car warms up, warmer air is flowing through the middle vents.
Some of those flaps are controlled by a plastic turn-pulley connected to a cable...
GRIDLOCK is offline   Reply With Quote
