Go Back   maXbimmer Forums > Classifieds > For Sale > Suspension & Brakes
Old 09-06-2006, 07:29 PM   #1
classicvista
classicvista's Avatar
Arrow BMW E46 Cross-Drilled and Slotted FRONT & REAR Brake ROTORS – NEW
Brand New
BMW E46 Cross-Drilled and Slotted Front & Rear Brake Rotors
Zinc Plated to Prevent Rusting
Price: $350
Contact Email: classicvista@gmail.com
Package Includes: 2 Front + 2 Rear Brand New, Zinc Plated, Performance Brake Rotors that fit E46 BMW
Cross-drilled and slotted rotors provide vehicles with the maximum braking under all conditions. Precision-machined holes/slots on the rotors allow hot gases from the brake pad to escape quickly in order to prevent skidding or locking up. Cross-drilled and slotted rotors provide quicker response to improve faster stopping power while enhancing the look of your car. As well, each rotor was entirely zinc plated to prevent rusting, and also made of the best quality metals. Cross-drilled and slotted patterns are precisely CNC machined for perfect fit to OEM specs for use with stock callipers and stock wheels. No other modifications are required.
Advantages of Drill Holes
  • Maximum air circulation for increased cooling. (200-250 degrees cooler)
  • Improved wet weather braking
  • Mill balanced to prevent vibration
  • Cooler brake pads
  • Longer rotor life
Advantages of Slots
  • Increased brake pad bite
  • Prevent glazing between brake pads and rotors
  • Shorten the braking distance
  • Release any gases, brake dust, water, and heat
  • - Slots were machined into the rotors at a 45 degree angle
  • - Smooth contact between rotor and brake pad
  • - Eliminate brake debris at the end of slots
  • - Rotor wear indicator
  • - Triangular end points
  • - Gases dissipate evenly throughout slots
Advantages of Zinc Plating
  • Protection against rusting on hub, edge, and vents
  • Lasts longer than powder coating, clear coating, spray paint, or any other methods
  • Better appearance
classicvista is offline   Reply With Quote
Old 09-06-2006, 10:40 PM   #2
BM4ever
Power seller
Where were you couple days ago I just bought these for almost double the price. Someone should grab these asap...
BM4ever is offline   Reply With Quote
Old 09-07-2006, 09:59 AM   #3
nyzryd3
how much just for fronts? need em soon..
nyzryd3 is offline   Reply With Quote
Old 09-07-2006, 10:13 AM   #4
classicvista
I am selling Front & Rear Rotors together.
Old 09-07-2006, 10:34 AM   #5
nyzryd3
thats too bad..would've been a sale..
Old 09-08-2006, 08:38 AM   #6
rmanaudio
Will you do $300 for a set for 01 325ci?
rmanaudio is offline   Reply With Quote
Old 09-08-2006, 09:54 AM   #7
classicvista
Currently, I have inquiries from other people for $350.
Old 09-08-2006, 10:57 AM   #8
cisco911
The 330s have bigger rotors(M3 size). Do you have this size?
Old 09-08-2006, 01:48 PM   #9
classicvista
You are right, 330 & M3 have different size.
Sorry, I forgot to mention in my ad: the rotors fit the following E46 BMWs: 328, 325, 323, 320.
Regards
