Old 09-04-2006, 09:12 PM   #1
bimmersport
bimmersport's Avatar
Some used parts for sale...
UUC tranny mounts, e36, black pair $40.00
UUC tranny mounts, e36, red pair $40.00
TMS rear shock mounts, e30/ e36/ e46, pair $60.00
Ground control rear shock mounts, e30/ e36/ e46, pair $60.00
Ground control shims (for trailing arms), e36/e46, $40.00 (for 4)
H&R rear ride height adjuster, $80 for both
Momo "Team" steering wheel 280mm/11", with black center (horn) $150.00
BIMMERSPORTAUTOMOTIVE
Specializing in BMW parts and service
905-670-9200
www.bimmersport.ca
bimmersport is offline   Reply With Quote
Old 09-04-2006, 09:22 PM   #2
bimmersport
905-670-9200
www.bimmersport.ca
Old 09-05-2006, 12:10 AM   #3
KIRASIR
Your Nightmare
KIRASIR's Avatar
Charlie,
If the adjuster will work with my H&R rear springs (they are MCoupe coil-overs, non-adjustable in the rear) consider it's sold. I need to raise the rear a bit. Do you have any pictures?
SL
Old 09-05-2006, 12:28 AM   #4
Soldo
Soldo's Avatar
How used are the shock mounts? Which will last longer/better for occasional track use?
Keven Soldo
Old 09-05-2006, 12:44 AM   #5
Boots R
Boots, not boost
Boots R's Avatar
I'd be interested in the steering wheel. What would be needed for install and how much would that cost?
Old 09-05-2006, 03:54 AM   #6
hey charlie, what do the H&R rear ride height adjuster do? I'm assuming they adjust the rear ride height, but how? Do i need any other equipment to make them work? I want to raise my rear end about 5 MM
Old 09-05-2006, 09:34 AM   #7
KIRASIR
Your Nightmare
KIRASIR's Avatar
If you need to raise the rear by only 5mm, get the thicker rubber pads under the springs. Look up ETK for part #s. (I think they are around 10 bucks each)
Old 09-05-2006, 11:51 AM   #8
You're not the first person to suggest that, but this time i think i might actually do it!
thanks kirasir, good luck with the sales charlie.
Old 09-05-2006, 01:36 PM   #9
cisco911
I thought the ground control TA shims were metal????
