Old 08-29-2006, 01:58 PM   #1
3SERB
3SERB's Avatar
Shake in Steering
I ve been getting a strage shaking in my streeting wheel lately what would cause this? The car was aligned only a few months ago, is it possible that it needs do be done again?
...VLAD...
3SERB is offline   Reply With Quote
Old 08-29-2006, 03:06 PM   #2
Proliphic
Trying to stay on 4wheels
Proliphic's Avatar
Send a message via MSN to Proliphic
possibly a bent/warped rim , or a slipped belt in the tire could be one of many different things.
Granite Silver '92 325i
Mark D (93) Chip
Motronix CAI
(Magic Fairy Dust )
Strut Brace
APEX Sport Springs
18" M3 CSL look-a-like's
Clear Corners All Around
6000K HID's
Thinline Angel Eyes
2.
Black/Silver 2000 Suzuki Hayabusa GSX1300R
8000K HID's
Clear Signals
(More to come)
Proliphic is offline   Reply With Quote
Old 08-29-2006, 03:23 PM   #3
mirek
mirek's Avatar
Alignment has nothing to do with shake in the steering. Check to make sure your rims are balanced, a weight could have just fallen off.
Old 08-29-2006, 03:24 PM   #4
98Dinan3
98Dinan3's Avatar
slightly bent rim caused steering wheel vibrations. And I mean SLIGHTLY. Moved it to the rear, and no shaking at all. Rotate your tires and see if it helps. It may atleast help you pinpoint it. Dave
Old 08-29-2006, 04:05 PM   #5
///Milan
///Milan's Avatar
Might be worn tie rods.
///Milan is offline   Reply With Quote
Old 08-29-2006, 04:48 PM   #6
Soldo
Soldo's Avatar
Could be lots of things.... if your tires are severly off ballance, it can cause some shaking. I had a very worn ball joint that cause servere shaking on the highway also
Keven Soldo
Old 08-29-2006, 04:56 PM   #7
3SERB
3SERB's Avatar
Well i just got a chance to check everything and all the pressure is ok, all the wheels have balancing weights on them. The shaking comes and goes its not constant and it always stops under the brake. Any other ideas??
...VLAD...
Old 08-29-2006, 04:57 PM   #8
Soldo
Soldo's Avatar
Could be warped rotors!
Keven Soldo
Old 08-29-2006, 05:26 PM   #9
3SERB
3SERB's Avatar
But it doesn't shake at all under braking only on accel and crusing. So Alignment wouldnt cause this problem??
...VLAD...
Old 08-29-2006, 05:30 PM   #10
mirek
mirek's Avatar
no.
Old 08-29-2006, 05:38 PM   #11
Replace the bushings on your front control arms. i bet that's your problem.
Does it happen a little more if you're turning on the highway? like long sweeping turns at 140-150 km/h+ starts rattling like crazy?
Take it to your mechanic (i suggest RMP, mirek would suggest Bimmersport)
Replacing the bushings on front control arms isn't too expensive, and i know RMP has a press to pop the bushings into the control arms.
For a quote, call 905 951 0002 and ask for rocco
