Old 08-21-2006, 01:14 PM   #16
JazzM
Another thing you can check is to make sure your wheels are balanced and properly inflated. This way you can see if there are any dents in the rim which can cause vibrations. Plus its the least expensive check.
You should check your tie rods as well. With the car jacked up see if there is any side to side play in the wheel.
Control arms and bushings should be replaced every two years if you drive your car hard as good maintenance practice. This will give you new bushings and ball joints. They will last longer however if you talk or check turner's website they recommed replacing them every two years.
Mine will be due this spring I will probably replace them over the winter.
T.
T.
Old 08-29-2006, 06:32 PM   #17
bikemx423
Bayern Motor Werks
Send a message via AIM to bikemx423
Does this take a genious to figure out u need new rotors?
bikemx423 is offline   Reply With Quote
Old 08-30-2006, 11:52 AM   #18
Quickid
See post #14..... he did that already
Quickid is offline   Reply With Quote
Old 08-31-2006, 12:39 AM   #19
ecuconnection
ecuconnection's Avatar
It doesnt take much to throw off your alignment. I ran on a track for 5 mins doing hard turns and the car was never the same again, prob shot my bushings to hell, doing it
Old 08-31-2006, 09:15 AM   #20
Danila318is
Send a message via ICQ to Danila318is Send a message via MSN to Danila318is
Guys, thanks for all your help. All I did was wheel balancing and the problem was gone!!!
Danila318is is offline   Reply With Quote
