Old 08-18-2006, 09:08 AM   #1
Danila318is
Send a message via ICQ to Danila318is Send a message via MSN to Danila318is
Question Steering wheel shaking while braking
Hello All,
When driving on a highway (100 km/h and up) when braking, my steering wheel starts to shake like crazy... Any idea what that might be? I'm thinking of changing all my rotors as well as the pads... Could it be that?
Thanks!
Danila318is is offline   Reply With Quote
Old 08-18-2006, 09:10 AM   #2
GladdoM3
GladdoM3's Avatar
it could me NEW ROTOR and PAD time, alignment or things of that nature......
take it too a shop. It is not that safe to have tremendous shaking, upsets the car.
Sold My M3. Got a New Subaru STI
GladdoM3 is offline   Reply With Quote
Old 08-18-2006, 09:23 AM   #3
JazzM
If it shakes only when you brake then its your front rotors that need to be replaced. You can try machining them but I would not recommend it.
T.
T.
Old 08-18-2006, 09:40 AM   #4
Danila318is
I have ordered BREMBO CROSS-DRILLED ROTORS for my e36, are they any good?
Hopefully they will solve my problem...
Old 08-18-2006, 10:30 AM   #5
v_bimmer
Jailbait FTW
v_bimmer's Avatar
i think its has nothing to do with the rotors, i had the same problem, took it to the shop and they did the allinment for me and the problem was gone!!!
Old 08-18-2006, 10:55 AM   #6
thinair
moderationistismingly
thinair's Avatar
What model car?
Old 08-18-2006, 11:40 AM   #7
Danila318is
It's 318 is, 1996
Old 08-18-2006, 11:52 AM   #8
///tyron
///tyron's Avatar
i have the same problem with my car. its brake pulsations, you need to replace the front rotors. for all 4 rotors from bmw will probaly run u around 400 bucks. good luck
///tyron is offline   Reply With Quote
Old 08-18-2006, 12:28 PM   #9
Danila318is
Thanks guys... Will be changing all my rotors tomorrow morning... Just in case, will go to the shop as well, and see if my wheels need an alignment...
Old 08-18-2006, 12:31 PM   #10
thinair
thinair's Avatar
Check the front control arm bushings while your there, that's what caused the vibration on my car.
Old 08-18-2006, 02:43 PM   #11
mirek
mirek's Avatar
Wheel alignment will not cause vibration or shaking.
Old 08-18-2006, 08:27 PM   #12
BigD
the misanthropist
BigD's Avatar
I'm with stupid, err Nelson, control arm bushings. Rotors could be warped too but tight bushings wouldn't let it feel that bad. Try braking harder in the meantime, that will reduce the shudder.
Old 08-18-2006, 09:56 PM   #13
Quickid
Yup, I had the same problem and it was the control arm bushings.
Quickid is offline   Reply With Quote
Old 08-21-2006, 09:05 AM   #14
Danila318is
I have changed the rotors as well as brake pads, it did not solve the problem... Went to the shop, they said my wheel alignment is good. Gonna go and replace control arm bushings & ball joints... Hopefully that will solve the problem...
Old 08-21-2006, 11:02 AM   #15
afc
afc's Avatar
i had the same symptoms when my caliper was failing. eventually it shook while driving.
a tip i got from a bmw mechanic wa to lube the pistons with brake fluid...i do it probably every 3-4 months and the caliper is still working and its been 1.5 yrs.
apparently if you do this to all your calipers regularly (once a year or so) you'll probably never have to replace them.
afc is offline   Reply With Quote
