Old 08-21-2006, 11:51 AM   #91
thinair
moderationistismingly
thinair's Avatar
Originally Posted by ///tyron
woah for over 8 grand u coulda got a 325is or even a 328is if u looked hard!for u to replace the engine with an m3 engine and transmission ur looking well over almost 6 grand with installation.
As a note, the 328 and M3 share the same transmission
Old 08-21-2006, 01:52 PM   #92
Soldo
Soldo's Avatar
But the M3 ZF tranny has deifferent gearing ratios..... doesn't it?
Keven Soldo
Old 08-21-2006, 01:55 PM   #93
thinair
thinair's Avatar
No, the ratios are the same, and the ratios are practically identical to the Getrag ratios in the 318/320/325.
Old 08-21-2006, 05:09 PM   #94
Soldo
Soldo's Avatar
So theres absolutely no difference in partn number, or anything mechanical in the ZF's found in 328's and M3's?
Keven Soldo
Old 08-21-2006, 07:22 PM   #95
thinair
thinair's Avatar
I believe the output flange is larger diameter because the M3 has a larger flexdisk/guibo.
Old 08-23-2006, 09:19 PM   #96
tboy356
Ripp a Gear
tboy356's Avatar
318's arent that bad. I have one, when it was compleatly stock yah it was slow.. but now its not too bad.. ive raced and bet many cars that were suppodto be faster then me.
next time im at a meet ill take someone for a ride.
tboy356 is offline   Reply With Quote
Old 08-24-2006, 12:04 AM   #97
PedroBMW
Hooked on Boost
PedroBMW's Avatar
tboy, what do u have done to your engine? cause even with a supercharger, I still don't think it has the speed of an m3.
http://www.foldingtrailers.ca
Old 08-29-2006, 06:29 PM   #98
bikemx423
Bayern Motor Werks
Send a message via AIM to bikemx423
You dont need to many mods at all to drift. Front strut bar helps. Put full psi in rear, 5 less in the front. You dont need turbos and stuff for all this... You just need to be a skilled driver. Practice in the rain...
Also you can get camber adjustment plates for fron suspension... Tune them so when you are looking at the car head on, the wheels look like they are tilted in... This helps rotate the wheels in cornering. It puts all traction flat on ground. This will help you car over steer... which will lead to drifting. But man, dont drift toooo much cause its lame unless your good.
Or do what i did and go to the local BMW dealer... and ask if they have any old e30's on the lot. I picked one up for 200$.... FUN DRIFT CAR!!
bikemx423 is offline   Reply With Quote
