Old 08-12-2006, 02:00 PM   #1
kapt_krickee
kapt_krickeet
kapt_krickee's Avatar
!!!!!!!!!!!Etest FAILED!!!!!!!!!
oh well, luckily I have donor cars...pulled the entire exhaust system out of the donor is...it passed with the previous owner...the mechanic that did the diagnostic is guessing that its the faulty cat............
anyways..anything you guys would suggest? I don't want it to fail again
thanks in advance
ps..1990 325IS
kapt_krickee is offline   Reply With Quote
Old 08-12-2006, 04:37 PM   #2
I tune-up if you havn't done one recently.
Maybe a new o2 sensor.
Dare I squeeze
Old 08-12-2006, 06:28 PM   #3
calegrant
A red bill, that usually does the trick. If he's an asshole brown may be required. Yes, I am serious.
Old 08-12-2006, 08:08 PM   #4
1BADRIDE
http://fuelly.3440.ca
1BADRIDE's Avatar
Send a message via MSN to 1BADRIDE
The cat can't be faulty - it's brand new (well, new as in never installed on a vehicle prior to that one).
O2 is recent as well.
Did you change the plugs like I mentioned? Plugs are older.
What were the readings?
Rahul
Life is good!
STUFF I NEED:
- Snow blowers, Chainsaws, Tampers
- Golf Carts, ATV's & Offroad vehicles, Kids vehicles
- ATV parts (Grizzly 700)
- Heavy equipment (front loader, backhoe, mini excavators, etc...)
PM ME WITH WHAT YOU HAVE!
1BADRIDE is offline   Reply With Quote
Old 08-12-2006, 08:29 PM   #5
woofster
woofster's Avatar
With older cars, many times it is the cat. However, I would definitely check the less expensive items first, like the sensors, valves, plugs and ignition wires.
2002 Audi A4 1.8T Quattro
2003 Acura MDX Touring
1992 BMW 318ic E30 cabriolet (sold)
woofster is offline   Reply With Quote
Old 08-13-2006, 02:24 AM   #6
Boris The Blade
same problem
I have the same problem. I just recently failed emissions test, I was over about 100 point. I explained to the guy that the car has been sitting for 2 years, he said to put a fuel system cleaner and fill the tank. do you guy think this will work? I dont want to fail again too... I'm guessing maybe it was bad gas in the car because the car passed inspection with flying colors the last time i inspected it then shortly after the car was parked for 2 years.
i think i could use a new o2 sensor too, my 02 sensor light is lit
John!
Boris The Blade is offline   Reply With Quote
Old 08-13-2006, 03:38 AM   #7
BMW325BMW
Commando
BMW325BMW's Avatar
in my case it cost me a brown and a red
BMW325BMW is offline   Reply With Quote
Old 08-13-2006, 08:55 AM   #8
woofster
woofster's Avatar
Which category were you 100 points over? HC, CO, NO? Idle or at speed?
It's also important to run the car up to normal operating temperatures before subjecting it to the emissions test. I know a lot of places don't do this.
Old 08-13-2006, 09:42 AM   #9
Boris The Blade
it was the NO should have been 534 or something and mine was 611
I can get the exact figures later, thier in my car. I'm also having a really hard time starting my car now. I stored the car with like almost no gas in it. Maybe the crap at the bottom of the tank clogged my fuel filter not sure. I'm gonna buy one today.
point is my car 2 years ago ran great and now crappy
John!
Old 08-13-2006, 10:41 AM   #10
e30countess
Mrs.Madchigga
If you left the car for long with almost an empty tank you probably have condensation or moisture build up forming corrosion inside your system.
e30countess is offline   Reply With Quote
Old 08-13-2006, 11:01 AM   #11
Boris The Blade
so what do I do to fix this problem...
John!
Old 08-13-2006, 03:20 PM   #12
europrince
I don't know about you, but instead of guessing at what the problem is, I usually have it hooked up to a diagnostic computer.
Old 08-13-2006, 09:41 PM   #13
e30countess
Mrs.Madchigga
Ya the computer will tell you if you have any leaks. Also you sometimes smell if you have leaks. Otherwise it is role up the sleeves, open the hood and/or pop the car on the hoist and start inspecting your whole fuel system, starting with the tank.
Old 08-14-2006, 04:56 PM   #14
1BADRIDE
1BADRIDE's Avatar
I doubt this will have an effect on emissions, moreso Boris' NO readings.
Europrince has the right idea.
Boris: Do the usuals - change the oil, FILL THE TANK WITH GOOD FUEL and run it down - repeat, reset the computer, change the plugs, and test your sensors. Unless you smell fuel, I would highly doubt there is a leak.
I *think* a bad NO reading points more to the catalytic than anything else, but I could be wrong. Verify with your local e-test techs.
Kapt Krickee - UPDATES?
Rahul
Life is good!
STUFF I NEED:
Old 08-15-2006, 01:07 AM   #15
kapt_krickee
kapt_krickeet
hey guys..thanks for all the input
I've already removed the donor exhaust system from header to muffler(all one peice with a new cat..pain in the a$$) this donor car passed when tested btw
so..getting that put in tomorrow..was going to do this either way anyways...
i'll ask him to double check oxygen sensor too...and I'll do the spark plugs..i use sunoco to fuel up...castrol GTX for the oil change...hmm..
he ran the diagnostics and everything checked out except for what his guess is ..the cat...says its supposed to lower the temp of the fumes b4 it gets out of the car? ..er...or was it the other way around?...but this wasn't happening with the cat on there now.......
again..thanks guys for all the help & support
