Old 08-10-2006, 11:13 PM   #1
oldskool3
oldskool3's Avatar
s52 or 19lb
Hey guys I am looking to upgrade my injectors and I was wondering should I go with 19lb injectors or ones out of an s52. I have heard that the s52 ones are better. Any opinions? Thanks
Old 08-11-2006, 07:03 PM   #2
The Sly
The Sly's Avatar
Did you not get some allready?
The Sly is offline   Reply With Quote
Old 08-11-2006, 07:14 PM   #3
The Sly
The Sly's Avatar
BTW if anyone is interested ..I have a set of M30 injectors for sale..
Oh and here is some pictures of a rebuilt on the way from Jesse's E30
M20b25
Being rebuilt also is a highly modified 34cc "i" head included a 272/272 11.5mm lift cam.
ENGINE BAY
ENGINE BLOCK with new timing belt, tensioner and water pump.
SLy
Old 08-11-2006, 07:46 PM   #4
Soldo
Soldo's Avatar
I have a set of blue injectors from a 95 325i, dunno how much they are, but lemme know if your interested
Keven Soldo
Old 08-12-2006, 10:05 AM   #5
For what motor?
In a 2.5, either is overkill. M50/S50 17.5lb/hr's are a much better match.
Old 08-12-2006, 05:32 PM   #6
The Sly
The Sly's Avatar
There you go Jesse...More pictures of your E30..
Old 08-12-2006, 05:42 PM   #7
Lee in Ottawa
Lee in Ottawa's Avatar
sly just got your pm. Looking good. Too bad the other parts never showed up.
Lee in Ottawa is offline   Reply With Quote
Old 08-21-2006, 11:16 PM   #8
sadi arbid
La Klasic
Need opinion and info.
what will the upgrade in the injetcors do ?
Anyone has the 17 lbs/S52 ?
PM how much ?
Any other things to change ? fuel regulator etc....
La Klasic
sadi arbid is offline   Reply With Quote
Old 08-22-2006, 12:16 AM   #9
Soldo
Soldo's Avatar
What injectors came with the M50 motors?
Keven Soldo
Old 08-22-2006, 07:34 AM   #10
Bob Loblaw
Zee Frog.
Bob Loblaw's Avatar
SLy
So it'll be running on propane, eh?
Bob Loblaw is offline   Reply With Quote
Old 08-22-2006, 11:36 AM   #11
Same as S50. 17.5lb.
Old 08-23-2006, 09:01 AM   #12
sadi arbid
La Klasic
too many questions needing answers from the PROs
What will the injectors do ?
What modifications are needed ?
How does you engine know you are dumping more fuel ? by the O2 sensor !
How does it adjust for that ?
What are the gains ?
Thanks for the help.
La Klasic
Old 08-23-2006, 09:56 PM   #13
They spray more fuel.
Nothing. But injectors alone will only hurt power output.
It doesn't know. That's why it works.
It doesn't adjust, early Motronic isn't very adaptive.
Gains only if you maxed out the stock injectors with other mods.
Old 08-24-2006, 09:12 AM   #14
sadi arbid
La Klasic
More confuse...
If you dump more fuel by swapping to larger flow injectors, you will run rich ! That will not produce more power .....unless you burn it.
To burn it, you need more O2 intake.....
How are you increasing your O2 intake ? I am not aware of any ways to increae O2 except turbo/supercharge/maybe increase thottle boar !! etc....
Your O2 sensor will detect rich mixture and cut back on fuel.....so even if you increase injector flow rate....the ECU will cut back as it detects rich.
Am I missing something ?
Please advise.
La Klasic
Old 08-24-2006, 01:59 PM   #15
Halfbroken
He might be also switching to m30 AFM and chipping?
Please advise.
He might be also switching to a an m30 AFM and chipping?
Halfbroken is offline   Reply With Quote
