08-03-2006, 09:35 PM
#1
Car: 86 325es b25
IE ss brake lines
Does anyone have there ss lines and if so how do you like them. Has anyone had any problems with them? Any other line suggestions?
08-03-2006, 10:07 PM
#2
Car: 86 325es b25
Also where do people buy there pads from. I was thinking of going with Axxis ultimate pads. Any oher suggestions? Thanks again
08-03-2006, 11:06 PM
#3
87325is///MR.EVIL
Car: 87 325 is/03 baige GRAND Am/94 white PROTEGE...
I am using the BMP ones my self,and for pads cannt remember what ones RUDYS dad put in...pm RUDY...
87is325///2.7L..EVIL.....
  03 beige GRAND AM and 94 white  (slamed)  PROTEGE
08-04-2006, 12:31 PM
#4
Car: E30 brilliantrot
i recommend SS lines with with some kind of protecting layer over SS braid
I have UUC ones and love 'em
08-04-2006, 12:45 PM
#5
Modeldater
Car: BMW M3/TRD Supra
For Pads I have Hawk HPS pads on which are awesome, and am hoping to go to SS lines soon too. Ive heard good things about the IE ones.
///M-TRD3
08-04-2006, 09:30 PM
#6
Car: Mini Clubman S
I have the UUC SS ones on my E30 M3........... they look pretty damn awesome. Seem to work just fine. I especially like the protective coating over the SS
08-04-2006, 10:26 PM
#7
^^ wise man
UUC ones are only slightly more expensive
08-04-2006, 11:06 PM
#8
Car: 86 325es b25
thanks for the info guys ill check out the uuc lines.
08-05-2006, 01:49 AM
#9
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
I have IE's, they work. I'm crazy and replace stop parts every two years anyway, so longevity isn't too much of a concern. Remember that no matter what SS line, they still have a rubber line inside, which deteriorates. I wouldn't go more than 5 years on a set of lines.
08-05-2006, 02:26 AM
#10
Car: 89 325i
Stainless Steel Brake Lines use teflon hose, which does not expand under pressure as much as a rubber hose, hence the firmer brake pedal feel. However, Teflon hoses will cut easier than rubber and are normally protected by a stainless steel braid to prevent failure of the brake line due to damage from road debris. I tend to agree that this is a part that should be replaced periodically as part of your routine maintenance. I can tell you from first hand experience, brake failures are no fun......
For what it is worth, I have stainless steel brake lines and love them but keep an eye on the entire brake system.
08-05-2006, 02:41 AM
#11
The SS is also so it doesn't expand, and it's a teflon LINED rubber hose if anything, teflon on it's own is just a coating to provide constant slippiness (technical term).
08-05-2006, 02:56 AM
#12
Car: 89 325i
Teflon is a material that can be used in many forms, including being made into a hose. Most, I will not say all, stainless steel brake lines are made the same fashion, a Teflon hose covered by a stainless steel braid to protect and support the hose. Some companies also use an external coating over the braid to provide further protection. Lets not even get started on what is needed for brake lines to be DOT approved....
IE Website Description:
Replace your tired old rubber hoses with teflon lined stainless steel braided hoses. A lot of brake problems like pulling to one side, sticking and draging calipers can be traced to hoses. The cost is actually about the same as new rubber lines and the SS lines will give a firmer peddle feel. These lines are not DOT approved.
UUC Motorwerks Website Description:
Inner TeflonŽ line is covered with woven stainless steel braid that will not expand under pressure. The advantages include better brake pedal feedback and a firmer pedal, along with superior brake modulation. Results will be immediate.
StopTech Website Description:
StopTech brake lines consist of a TeflonŽ inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing
04-10-2007, 07:40 PM
#13
Car: E30 Vert2.7iNitrous
guys while we are on the subject of SS brake lines ..A stupid question for ya.
6 lines comes in the package and i know of 4 where they go but what about the other 2??
Sly
04-10-2007, 08:01 PM
#14
The Afro-stig
Car: Is Fast. ;)
id guess if theres a set of 6 then 4 are for the two rubber brake hoses in the rear on each side and the other 2 lines are for the front. did your kit not include a line for the clutch slave cyl?
04-10-2007, 09:06 PM
#15
Car: e36 m3
there are two additional hoses that go from the bottom of your car onto the rear sub-frame.
They are usually a bitch to replace.
